How can a compass suddenly go out by 20 degrees?
Old February 15th 04, 04:41 AM
Bob Chilcoat
Default How can a compass suddenly go out by 20 degrees?
Recently one of my partners reported that the compass (standard whiskey
compass, not a vertical card) on our Archer was reading 20-25 degrees off of
runway heading at departure. Today a new partner was up with an instructor
for his sign off and reported the same thing. I hadn't noticed, but we seem
to have a definite problem. Nothing has changed in the plane for a long
time. We recently replaced the old Garmin GPS with a Lowrance AirMap 300
(which has its antenna on the top of the glare shield near the compass), but
the first incident was before that substitution was made. Any idea how
something like this can happen?
Bob (Chief Pilot, White Knuckle Airways)
Old February 15th 04, 06:08 AM
Jay Smith
Move the antenna and you will observe the compass swing. Although the
antenna cable is theoretically shielded (?), the leakage of the electric
field affects the adjacent magnetic field, thereby affecting the
magnetic compass.
Old February 15th 04, 06:41 AM
Don Tuite
On Sun, 15 Feb 2004 05:08:30 GMT, Jay Smith
magnetic compass.
Doubtful. No DC. A screwdriver in the glove box is more likely.
Don
Old February 15th 04, 08:39 AM
Mark Mallory
I had a problem with the Airpath compass in my '182, which at first seemed very
similar to what you describe. Turns out it wasn't a magnetic-field-related
problem; rather, the compass was simply "sticking". The compass has a flexible
diaphragm at the rear of the housing to allow for fluid expansion; the diaphragm
is separated from the main volume of the housing by a thin (non-magnetic) metal
plate. Apparently, pressure changes had caused the diaphragm to force the plate
forward, such that it would occasionally come in contact with the compass card,
causing the card to stick. The sticking would only happen on certain headings
with certain pitch attitudes; it worked fine most of the time.
I replaced the original compass with the same model Airpath, but after about two
years the replacement compass developed the same problem! I finally replaced IT
with one of these:
http://www.vargaair.com/navigator.htm
which works great (looks cool at night too.)
Mark/C182L
Old February 15th 04, 03:04 PM
Roy Smith
There are two basic possibilities:
1) Something is wrong with the compass. Things that can go wrong with
compasses include leaking fluid, worn or damaged bearings, or somebody
twiddling with the conmpensation magnets.
2) Something changed in the environment the compass operates in. The
aircraft has its own magnetic field. What the compass senses is the
(vector) sum of the Earth's field and the aircraft's field (this is what
the compensating magnets compensate for). If you've had equipment
installed or removed, or wires re-routed, this could cause the problem.
Note that "installed" doesn't mean it's got to be bolted in. If it's in
the plane, it'll affect things. Maybe your partner is carrying
something in his flight bag that might affect things?
Old February 15th 04, 03:56 PM
rip
Actually, I think most GPS antennae do receive DC through the coax to
power the preamplifier in the antenna.
Rip
magnetic compass.
Don
Old February 15th 04, 04:10 PM
Dave Stadt
"rip" wrote in message
. com...
Rip
You are correct. My Garmins do exacly that.
off of
instructor
seem
long
300
compass), but
magnetic compass.
Don
Old February 15th 04, 05:21 PM
RJ
Bob,
This happens with precision when I turn on the airconditioning in my
Bonanza. (It's described in the POH.) While I realize you're probably
not running AC in the winter, it does show how equipment can affect
the compass. Have you noticed a difference with and without the master
turned on?
Rob
Mark Mallory wrote in message ...
with one of these:
Mark/C182L
Old February 15th 04, 08:21 PM
Jim Weir
Oh, fer corn sake. Not likely. The cable isn't theoretically shielded, it is
shielded. The leakage of the electric field? You mean the e-field of the
sub-microvolt GPS signal or the e-field of the three or four milliamps into the
antenna amplifier? Not likely. Not through a tinned copper braid shield.
More likely that the antenna has a steel mounting plate. Move the antenna or
remove the mounting plate.
Jay Smith
-Move the antenna and you will observe the compass swing. Although the
-antenna cable is theoretically shielded (?), the leakage of the electric
-field affects the adjacent magnetic field, thereby affecting the
-magnetic compass.
http://www.rst-engr.com
Old February 15th 04, 08:30 PM
Don Tuite
Ok. But he should check the glovebox anyway.
Don
On Sun, 15 Feb 2004 14:56:03 GMT, rip
Rip
magnetic compass.
Don
Reading the whiskey compass Ben Jackson Instrument Flight Rules 20 February 28th 04 09:09 AM
Strange compass behavior me Owning 10 February 14th 04 05:24 AM
"Whiskey" for compass? dale Home Built 10 December 18th 03 12:16 AM
I'm lost. Which compass? Greg Burkhart Home Built 1 August 12th 03 04:49 AM
Vertical Card Compass compatible with "V" brace? Jeff P Owning 1 July 11th 03 04:46 AM
