Flaps VS Airbrakes/Spoilers
Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem.
I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. Walt |
On Aug 15, 2:57*pm, Walt Connelly Walt.Connelly.
wrote: Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. *I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? *Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. *It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem. I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. Walt -- Walt Connelly Check out the Mini Nimbus, Mosquito and early Ventus. |
On 8/15/2011 2:57 PM, Walt Connelly wrote:
Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? The 'purpose of flaps' - Is this where philosophy enters the aerodynamic world definable by flaps' effect on a glider's polar? To me, viewed most generally, the purpose of (large deflection landing) flaps is identical to the purpose of spoilers, i.e. to ease Joe Glider Pilot's task of safely making a landing pattern into 'glider-size' fields...different ways to skin the ease/safety cat. Beyond that, both options come with their pros & cons. Again to my way of thinking, it would be a 'glider shame' to wantonly disregard/not use the flap-related effect of increasing the max lift inherent in the use of the simply-hinged flaps used on (say) every 15-meter FAI-class ship around and most 15-meter span ships. That's true even if the ship uses its flaps 'only' for optimizing the drag bucket of the airfoil in cruise (i.e. they don't deflect much beyond ~20-degrees). Stated another way, if Joe Glider Pilot's ship has (small deflection, 'intended for cruise optimization-only') flaps, in conjunction with intended-for-landing spoilers, why *wouldn't* JGP go to max positive deflection flaps before then using spoilers for primary glidepath control? He still would (could) obtain a theoretical lower touchdown speed benefit contrasted to not using the flaps. Where I'm headed with this is, one can reasonably conclude the 'purpose of flaps' is whatever JGP decides, within their aerodynamic capabilities. You've noted above, one possible purpose...and others have (and probably will again!) note this particular purpose comes with its own safety-based 'recommended user guidelines!' In other words, there's nothing about having (only) large deflection landing flaps that *insists* one make the whole approach below the flaps-off stalling speed. I generally did so only under absolutely benign conditions, otherwise until 'somewhere around' flare altitude keeping my speed at or above the flaps-off stall speed, less from fear of 'falling out of the sky like a brick' should I (for whatever reason) instantaneously dump the flaps, and more because it simply provides a larger margin (margins being good in my book). However, in any pattern conditions that I thought safely permitted, I also sought to minimize my touchdown speed (whether on or off airport) by *using* the extra lift inherent with flaps to minimize my *touchdown* speed...easiest on the the equipment, if nothing else. Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. "Roger that...and folks will probably 'O-beer-thirty' argue if that point is 30-degrees, 45-degrees, or more." Pick whatever number you like for now! It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem. ....and beyond, if you have the height margin and hand-eye skills... I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Only the AS W-20A in the large deflection w. spoiler field that I know of, but lotsa designs with small-deflection flaps with spoilers. And, of course, the 'don't fit precisely into either category' ships like Mosquito, Vega, Mini Nimbii, early Ventii, etc., which have their own devils in their own details! Such fun!!! Sometimes too many opinions from too many people are a bad thing. Heh! Regards, Bob W. |
On 8/15/2011 1:57 PM, Walt Connelly wrote:
I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. There are lots and lots of them out there! Starting with the ASW 20, all Schleicher flapped gliders have had "high deflection" landing flaps and spoilers. ASW 20, ASW 22, ASH 25, ASH 26, ASW 27, ASG 29, and so on. "High deflection" ranged from 40 degrees to 60 degrees. None of them had full deflection flaps. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Aug 15, 4:57*pm, Walt Connelly Walt.Connelly.
wrote: Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. *I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? *Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. *It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem. I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. Walt -- Walt Connelly Landing flaps are quite effective in many ships and really effective in a few. Really effective examples: HP series, Concept 70, PIK 20- all are flaps only In these ships, you usually don't put full flap in till you have the field made with margin. Then, if high, just put the nose down a bit more and down they come. Because they are so effective, there is rarely any reason to raise them again because you are plenty high. Flare needs to be soon enough to begin to bleed speed a bit before going into ground effect to reduce floating down the airport. I once landed my PIK-20 in a football field over the goal post. Most effective: ASW-20 early before B and C. Flaps plus spoilers. Steep approach, no speed build up , min float in flare. I landed my 20 over the goal post and stopped with lots to spare. "Not quite like 20"- 20B and C, ASH-26, ASW-27, ASG-29. Excellent, but go around the goal post . Really effective- 1-35. Around the goal post Others- The Glasflugel and SH gliders with trailing edge flap brakes also come down quite well. One benefit is that they are intuitive to use and easy to transition into. There is no reason to be afraid of flaps only ship. That said, you must get some good prep and training to learn how to do it right and that does NOT come from RAS posts. There is a lot of bad info that is hard to weed out. FWIW UH |
wrote: Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. *I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? *Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. *It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem. I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. Walt -- Walt Connelly I have been flying a Laister LP-15 Nugget for about three years now and I love the glider as well as the flap system. On the Nugget, the flaps are super simple, working more like spoilers in terms of function. One caution on flapped ships is that some are too complex and make things tougher while landing. I'm sure that once a pilot is dialed into what ever he or she is flying it becomes second nature though. |
Get a Kestrel and have both... (and a drag chute for good measure)
On 2011/08/16 3:00 PM, Blake Seese wrote: On Aug 15, 2:57 pm, Walt ConnellyWalt.Connelly. wrote: Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem. I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. Walt -- Walt Connelly I have been flying a Laister LP-15 Nugget for about three years now and I love the glider as well as the flap system. On the Nugget, the flaps are super simple, working more like spoilers in terms of function. One caution on flapped ships is that some are too complex and make things tougher while landing. I'm sure that once a pilot is dialed into what ever he or she is flying it becomes second nature though. -- Bruce Greeff T59D #1771 & Std Cirrus #57 |
On Aug 16, 8:51*am, wrote:
There is no reason to be afraid of flaps only ship. That said, you must get some good prep and training to learn how to do it right and that does NOT come from RAS posts. There is a lot of bad info that is hard to weed out. FWIW UH Agreed. On RAS even the normally sane, competent, always-within-his- limits UH starts telling stories of landing over and between goal posts. :-). -T8 |
Here are a few links that can be used as guides to flying flaps-only ships.
http://www.soaridaho.com/Schreder/Large-span_flaps.html http://www.soaridaho.com/Schreder/St..._HP_flight.htm http://www.soaridaho.com/Schreder/St...r_on_Flaps.htm http://www.soaridaho.com/Schreder/HP...st_Flight.html I know this is more information then you really want to know. Sorry about that! Wayne HP-14 "6F" http://tinyurl.com/N990-6F "T8" wrote in message ... On Aug 16, 8:51 am, wrote: There is no reason to be afraid of flaps only ship. That said, you must get some good prep and training to learn how to do it right and that does NOT come from RAS posts. There is a lot of bad info that is hard to weed out. FWIW UH Agreed. On RAS even the normally sane, competent, always-within-his- limits UH starts telling stories of landing over and between goal posts. :-). -T8 |
wrote: Well about half of the posts re flaps only gliders made me feel positive about the possibility of finding a glider with flaps only, and the other half made me feel just the opposite. *I guess you could dump flaps on final rather quickly if your speed was above stall for all ranges of the flaps as they came up but the purpose of flaps is to create more lift allowing for a lower approach speed or am I mistaken? *Apparently beyond a certain point the flaps cease to provide lift and are only a drag device. *It would make sense that a quick move from the drag area back to the maximum deflection for lift could be accomplished quickly with little problem. I guess the best option is for a glider with both flaps and spoilers/airbrakes but I don't think there are a lot of those out there. Sometimes too many opinions from too many people are a bad thing. Walt -- Walt Connelly My personal favorite get the glider down right now device is a drogue chute. My Open Cirrus had one in the bottom of the rudder, and the one time I really needed it on a landout, it worked like a charm. I practiced with it once and deployed it from 800 FT over the numbers at SPA, the glider was on the ground and stopped between the vasi's. You have to put the nose over rather smartly to keep the chute from pulling the glider into a stall, but man it brings it down in a hurry. The Open Cirrus I used to own is up for sale again, so for a nominal fee, you too can have a drouge chute equiped glider. SF |
Similar Threads | ||||
Typical glide angles with airbrakes deployed | Ronald Locke | Soaring | 8 | February 15th 11 08:31 PM |
Full-span flaperons as airbrakes? | Bret | Soaring | 21 | March 20th 10 10:39 PM |
Spoilers or Airbrakes - Whats in a name? | ContestID67 | Soaring | 29 | May 20th 08 05:21 PM |
Flaps/spoilers on which sailplanes? | [email protected] | Soaring | 11 | December 31st 06 01:12 AM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
