Is a "yellow-tag" really necessary?
Old March 7th 04, 10:01 AM
Andre
Default Is a "yellow-tag" really necessary?
Ok, let's say my TSO'd Attitude Indicator (AI) in my Cherokee goes
belly-up, and my friend just happens to have one he removed from his
machine a month ago as part of a complete panel upgrade. We both KNOW
the thing works fine and would solve my problem.
What's the ramifications of just having it installed in my Cherokee?
Is it OK without a yellow-tag? If not, why not? Isn't there any
discretion on the the part of the mechanic to install a part he has
observed as functional in one airplane and put it directly in another?
I hear if you ask an instrument shop to check it out and yellow-tag
it, they will often refuse unless you pay them to do a COMPLETE
OVERHAUL. Is that true?
What's the straight skinny on all this, guys?
Thanks...
Andre
Old March 7th 04, 02:32 PM
Dennis O'Connor
When he gives you the gyro have him rummage in the airplane folder and give
you the yellow tag or mfg's sticker that the mechanic had to have to
install it into his plane... That's all your mechanic needs...
denny
"Andre" wrote in message What's the straight skinny
on all this, guys?
Thanks...
Andre
Old March 8th 04, 06:16 AM
Andre
Stu Gotts wrote in message . ..
If the part is a certified one (doesn't have to be TSO'd) and is
listed as a direct replacement, all that is necessary is a proper log
book entry.
An instrument shop can inspect and return the part to service "yellow
tagged". They would probably insist of tweaking it which will cost
you the same as having it o/h'd. If it works, put it in. When it
dies, replace it.
Stu,
Thanks to you and the others for your post. What I need to find out
is what to tell the mechanic when I hand it to him (with no
yellow-tag).
It sounds like all I have to say is that the gyro is listed as a
direct replacement (I assume a Sigma-Tek 5000B-36 IS a direct
replacement), that it is in working condition, so JUST INSTALL it and
make a logbook entry.................please...
Does that sound correct?
By the way, where WOULD I find a list of approved replacement attitude
indicators for an Arrow II?
Andre
Old March 8th 04, 06:22 AM
BTIZ
any reputable mechanic will check the part numbers to make sure it is an
"approved replacement"..
ask your buddy to go through his logbooks and get the yellow tag
BT
m...
book entry.
dies, replace it.
Stu,
yellow-tag).
Andre
Old March 8th 04, 05:42 PM
Andre
"BTIZ" wrote in message news:lqT2c.17428$id3.8997@fed1read01...
BT
m...
book entry.
dies, replace it.
Stu,
yellow-tag).
Andre
BT,
In the REAL story, this instrument was bought from a guy who acquired
it as part of a fairly complete RV-6 homebuilt package but didn't need
either the AI or the DG, so he's selling them to me. Unless the guy
HE got the RV-6 package from has a yellow-tag (or manf'r tag), I doubt
I'll be able to acquire one. I WILL try and track down the guy he got
it from, anyways, on the outside chance he might have something
although it's been over a year.
I was just hoping to avoid the hassle and get my mechanic to install
the thing, and needed some advice on what resistance I might get from
him.
Andre
Old March 8th 04, 06:31 PM
Jim Weir
A mechanic who understands how the real world works is worth his weight in
unicorn dung. Stop looking for a yellow tag and start looking for a real
mechanic as opposed to a paper shuffler.
(Andre)
-I was just hoping to avoid the hassle and get my mechanic to install
-the thing, and needed some advice on what resistance I might get from
-him.
-Andre
http://www.rst-engr.com
Old March 9th 04, 01:45 AM
BTIZ
bottom line... it's up to your mech..
BT
om...
BT
m...
his
KNOW
Cherokee?
another?
log
book entry.
"yellow
dies, replace it.
Stu,
yellow-tag).
Andre
BT,
him.
Andre
Old March 7th 04, 05:32 PM
Newps
This is exactly what I did with a DG. Someone on these boards was
gutting the panel and going with all new stuff. I bought the DG because
the one in my plane was acting up. Just swapped it out, didn't bother
to log it and away I go. There is no reason to have a yellow tagged part.
spinner paint scheme Dick Home Built 3 January 27th 05 10:58 PM
Overall yellow Fw-190A-6 ??? Vicente Vazquez Military Aviation 5 April 20th 04 01:05 AM
Yellow tags Mike Z. Owning 13 February 21st 04 02:23 AM
Yellow, yellow. Fil330 Owning 1 November 2nd 03 04:13 PM
blue foam, pink foam, yellow foam? Corrie Home Built 26 September 1st 03 06:01 PM
