I just had a VFR Cert. done and the avionics shop said that the antenna
of coax was causting the frequency of the transponder to be out of limits. Of coarse they had to bench adjust the frequency of the transponder to compensate. Has anyone ever had this problem before? Thanks, Ray |
Ray,
I have seen this multiple times. I've seen very large swings in freq and when the problem was fixed, the xponder was back where it needed to be. The cause of the frequency shift should be fixed, not adjusting the radio to compensate for it. It could be a bad connector or a corroded antenna mount. If you fix it right, then you should be trouble free for the next inspection. Dave Ray Godwin wrote: I just had a VFR Cert. done and the avionics shop said that the antenna of coax was causting the frequency of the transponder to be out of limits. Of coarse they had to bench adjust the frequency of the transponder to compensate. Has anyone ever had this problem before? Thanks, Ray |
Unfortunately, the frequency that the transponder transmits on is
determined by a vacuum tube in a cavity resonator. Anything that changes the physical dimensions or impedance of the cavity detunes it, causing a frequency error. Changing the coax/antenna shouldn't be enough to mistune the cavity, but if it was off to one side already, then a changed load impedance could send it off far enough to fail the test. A good transponder check measures the center frequency of the transponder pulse while the transponder is in the aircraft... MikeM Ray Godwin wrote: I just had a VFR Cert. done and the avionics shop said that the antenna of coax was causting the frequency of the transponder to be out of limits. Of coarse they had to bench adjust the frequency of the transponder to compensate. Has anyone ever had this problem before? Thanks, Ray |
I would be looking for rust or water in the RF connectors and the
antenna ground connections of the transponder antenna. The tube that is used for the older transponders is affected by the load impedance of the coax and antenna. If the impedance changes then the TX frequency changes. Mine is still on frequency even after 27 years without adjustment. John On Thu, 11 Mar 2004 00:49:41 GMT, Ray Godwin wrote: I just had a VFR Cert. done and the avionics shop said that the antenna of coax was causting the frequency of the transponder to be out of limits. Of coarse they had to bench adjust the frequency of the transponder to compensate. Has anyone ever had this problem before? Thanks, Ray |
Idents on VOR+DME if one of them is inop | Robert M. Gary | Instrument Flight Rules | 14 | January 24th 05 10:10 AM |
Optimal Frequency of Lessons | David B. Cole | Aerobatics | 18 | October 28th 04 12:50 AM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
[FA] - New Hampshire NH Frequency Guide 7th Edition (Coburn) | Ken | Aviation Marketplace | 0 | January 19th 04 05:58 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
