Commercial Ejection Seats on homebuilts?
Old December 22nd 03, 07:25 AM
David Findlay
Default Commercial Ejection Seats on homebuilts?
Has anyone bought a commercial ejection seat for use on their homebuilt
aircraft? Is this even feasible? Thanks,
David
Old December 22nd 03, 09:35 AM
Cam
I heard on Discovery channel they cost around 1M a pop, so I'd imagine they
would be out of the homebuilt market.
Cheers cam
"David Findlay" wrote in message
u...
David
Old December 22nd 03, 03:54 PM
C.D.Damron
I think there is a civil model marketed at $200K.
"Cam" wrote in message
they
Cheers cam
u...
David
Old December 22nd 03, 05:31 PM
DJFawcett26
Actually, you can buy a Russian seat, the KSS-42 manufactured by Zvezda for
approximately $70 K. It is an exceptional seat capable of 0/0 with 900 km/hr
max velocity. Best part is that it only weighs 45 kgs. compared to 200 lb.
plus for the Martin Bakers which cost mega bucks.
Old December 22nd 03, 02:14 PM
EDR
In article , David
How much weight are you willing to add to the Empty Weight of your
aircraft?
Old December 22nd 03, 02:22 PM
BllFs6
Well
you could buy one of those emergency ballistic chutes that they make to recover
the WHOLE plane under a parachute....a BRS i think they are called?
they only cost a few thousand dollars and weigh 10s of pounds....
It would take some research/engineering to the following but it seems
possible...
make it so when the chute is ejected/deployed by the rocket the force of the
inflated chute drag is enough to rip out a safety cage/reinforced cabin area
and the rest of plane plumets to the ground...
those chute deploy on the order of a second or so...
take care
Blll
Old December 22nd 03, 09:51 PM
James R. Freeman
David:
Ejection seats come up for sale all the time on the G.S.A. auction site
under aircraft parts. The minimum bid is $3000 USD if Remember correctly. I
think weight would be the problem.
u...
David
Old December 23rd 03, 01:39 PM
Getstuffed
"James R. Freeman" wrote in message
David:
site
I
The power of the charge that expels the pilot from a crippled aircraft is
far more than a homebuilt or GA aircraft could bear. The structure would
simply fail. Your best best is a recovery chute save yourself and the plane.
Old December 23rd 03, 04:40 PM
RR Urban
Forget the recovery chute for most homebuilts, too.
The majority of airframes are not designed for an
aftermarket recovery chute attach point, the shock
loads or even safe deployment without rigorous,
tedious and expensive R&R. Then there is the
trade off issues of weight reducing the payload,
range and performance.
Rarely does a major airframe package fail.
Wings seldom fall off without provocation.
So, in most cases, 'tis far more practical and
do-able to just GUIDE the aircraft to a safe TD...
even in treetops.
Most failures are... plain old fuel starvation with
CFIT ranking quite high, as well. Bang for the
buck would dictate that efforts be expanded in
schooling pilots in these failures before attempting
a costly idiot proof airplane of marginal performance.
Neither screw up calls for a pricey parachute with
the problems associated with attaching and then
perfecting the package for an 'iffy' deployment.
If all else fails, WEAR a parachute. It has not the
high tech flavor that some here would embrace,
but damn.... it is simple, cheap and it works!
Barnyard BOb - powered flight is a gas, er, requires gas
Old December 24th 03, 02:45 AM
Peter Dohm
even in treetops.
I agree completely!
Peter
Homebuilts by State Ron Wanttaja Home Built 14 October 15th 03 08:30 PM
Looking for ejection seats Rafi Yoeli Home Built 1 July 15th 03 05:43 AM
