anyone done this...avionics guy says it outputs
nmea over rs232. any special software needed? |
Most GPSes have an NMEA RS232 output; all mine do.
Wire GPS_Data_Out to Pin 2 of your computer Serial Port. Wire GPS_Ground to Pin 5 " " " " " Fire up HyperTerm, establish a "connection" to the appropriate Com port using 4800,N,8,1 (it might be 9600,N,8,1?). Everything the GPS sends will print on the screen. You can capture it in a file, if you want. Google for "NMEA sentences" if you want more info about what is printed. MikeM Baron Man wrote: anyone done this...avionics guy says it outputs nmea over rs232. any special software needed? |
GWB and the Air Guard | JD | Military Aviation | 77 | March 17th 04 10:52 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
value of Bendix / King klx100 | mah | Aviation Marketplace | 1 | December 19th 03 03:19 AM |
Bendix King GPS Updates | Matthew Waugh | Instrument Flight Rules | 1 | August 5th 03 06:11 PM |
Bendix King GPS Updates | Matthew Waugh | Owning | 1 | August 5th 03 06:11 PM |
