Good Electrical shop in NorCal
Old May 6th 04, 02:07 AM
Robert M. Gary
Default Good Electrical shop in NorCal
I have a strange, intermittent charging problem in my Mooney and am
looking for a good electrical shop. I've changed out the alternator,
battery, regulator, field wire, alternator ground wire and several
other items and I'm still having a charging problem. I'm looking for a
shop that knows how to debug an electrical problem, not just R&R
parts.
-Robert
Old May 6th 04, 06:53 AM
Michelle P
Robert,
How good is the ground between your engine mount and you airframe.
Measure the voltage drop across the two if there is any then you found a
problem.
Michelle
parts.
-Robert
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old May 6th 04, 06:21 PM
Robert M. Gary
Michelle P wrote in message link.net...
Robert,
problem.
I put two brand new wires there. I figured I should double up my
grounds. (actually the ground runs right from the back of the
alternator to the frame).
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 08:20 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
