Sharing Costs
Old May 15th 04, 03:53 AM
Eddie Sanderford
Default Sharing Costs
I have a Cessna 172 that is not flown very often. I have been approached by
an EAA chapter that wants to use my craft for their Young Eagles training
program and have offered to pay an hourly rate for use of the aircraft in
non-commercial operations. I have a non commercial insurance policy and
could "name" the two pilots who would be piloting the aircraft. The rate of
reimbursement would be calculated on the operating cost (including fixed
cost, engine and avionics reserve, airframe maintenance, etc.)
I can't get a definitive answer from the FAA if this would be allowable
under the "shared expense" provisions of the FARs Part 91.
I would appreciate comments from any who has expreience with this type of
arrangement.
Thanks
Old May 15th 04, 12:45 PM
Richard Kaplan
"Eddie Sanderford" wrote in message
by
of
If you are not doing the flying then this is not an FAA issue in regard to a
commercial operation. The only potential FAA issue would be if you need
100-hour inspections, but if you are supplying only the airplane and not the
pilot then it would not be considered a "for hire" operation by the FAA and
thus you do not need 100-hour inspections.
The main issue I see here would be for you to check with your insurer that
you are covered when your airplane is used in this manner. Some companies
offer "limited commercial" policies for this reason. Some policies do not
consider this to be a commercial operation if you just recover costs. Some
policies would indeed consider this type of operation to be commercial --
again I say "commercial" operation is a concern not from an FAA standpoint
but rather from an insurance standpoint.
Richard Kaplan, CFII
www.flyimc.com
Old May 17th 04, 04:02 AM
BTIZ
this is not a shared expense issue... because you are not in the aircraft at
the time of usage to share the expense..
this may border on "providing a rental aircraft".. it does not matter that
you only rent if for cost.. or even at a loss.. the Fed's don't care if you
are a poor businessman... but it is the "intent" of renting..
BT
by
of
arrangement.
Thanks
Lockheed's JSF Costs to Rise $45 Billion Henry J Cobb Military Aviation 3 April 6th 04 09:33 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
True costs of a light twin... Captain Wubba Owning 20 November 20th 03 02:32 AM
LOOKING FOR COST SHARING Corey Bonnell Owning 0 October 19th 03 09:04 PM
Canadians: Estimate monthly costs? Drew Hamilton Owning 9 July 28th 03 12:32 AM
