DG "service contract" revisited
Old October 21st 11, 11:55 AM posted to rec.aviation.soaring
Lars Peder Hansen
Default DG "service contract" revisited
Finally, someone is taking legal action against DG Flugzeugbau.
Those who understand German can follow the Nordrhein-Westfalen chapter of
the German Aeroclub he http://www.aeroclub-nrw.de/htmd/01h-aktuelles.htm
On a related note, the EASA continues to sabotage DG's effort to force us to
sign contracts, in order to obtain new manuals. The updated Type Certificate
Data Sheets for LS gliders clearly state that you can use the old OR the new
(May 2011) manuals.
http://easa.europa.eu/certification/...S_Sailplanes-0
Also, DG tries to force you to pay for the contract in all the years from
2009 if you need a service in, say, 2016. Apart from being extremely
questionable from a legal standpoint, this raises the question: Why should
anyone pay for a yearly contract with DG at all, then? It is much better to
put an equivalent sum into your own savings account, so you are able to pay
ransom money if ever needed. Meanwhile, the interest you earn on your own
money may buy you a Flarm, or enable you to take the wife / girlfriend (or
both) out for an evening in town.
Happy soaring,
Lars Peder
Replace numbers with post1.tele.dk to answer by email
Old October 21st 11, 01:01 PM posted to rec.aviation.soaring
Andrew Warbrick[_2_]
Default DG
to
Certificate
new
(May 2011) manuals.
to
pay
Happy soaring,
Lars Peder
I don't think EASA had much option but to include all the old flight and
service manuals in the TCDS. DG are serial numbering the new manuals to
each individual glider to discourage copying or lending. Surely that means
that if DG haven't provided a "new" manaul for your glider then the
original manual is the latest one available for your individual glider
because there is no "new" manual with your exact serial number.
Of course if DG have created a serial numbered manual for your glider then
they are breaking the law (specifically EC regulation 2042/2003) by not
"making available" the "updated" manauls to the aircraft owner/operator.
Old October 21st 11, 01:26 PM posted to rec.aviation.soaring
Lars Peder Hansen
Default DG
They try to make it look like the manual is tied to the individual glider,
by creating a front page with the ac. serial number and some kind of
internal DG checksum. As we all know this is against regulations.
Our local National Aviation Authority in Denmark require the new manuals
used in maintenance programs, but they specifically state that it does not
need to be tied to any specific ac, and that owners "are not required to be
part af a subscription program of any kind". I guess that is the closest
they can come to saying "copy away, folks!" ;-)
Lars Peder
"Andrew Warbrick" wrote in message
.com...
to
Certificate
new
(May 2011) manuals.
to
pay
Happy soaring,
Lars Peder
Old October 21st 11, 01:44 PM posted to rec.aviation.soaring
jcarlyle
DG has another distasteful business practice that isn't well known,
yet. If you sign up for the service contract, they will automatically
(without even asking you in advance) charge your credit card for
subsequent years. Guess how I know?
-John
On Oct 21, 6:55 am, "Lars Peder Hansen"
the German Aeroclub hehttp://www.aeroclub-nrw.de/htmd/01h-aktuelles.htm
(May 2011) manuals.
http://easa.europa.eu/certification/...ocs/aircrafts/...
Happy soaring,
Lars Peder
Old October 21st 11, 02:48 PM posted to rec.aviation.soaring
ContestID67[_2_]
I live in fear that one day I will need some semi-trivial inexpensive
part (i.e. springs in the airbrakes) for my glider and have to pay the
"DG-ransom" to obtain said part, back dated to time immemorial.
On top of that my glider has a Standard Airworthiness Certificate
(rather than Experimental*) which limits what I can do to replace that
semi-trivial inexpensive part. Any thoughts on conversion from
Standard to Experimental? Does that help me in any way? Or is there
a downside such as lowering the resale value?
Thanks, John
* I own a DG-101G ELAN. If you look at
http://registry.faa.gov/aircraftinqu...DG-10&PageNo=1
you will find that it is about 50/50 if any particular DG-10X is
Standard or Experimental certified. Was it common practice back in
the 80's to pick/choose Standard versus Experimental? What was the
rational when choosing one over the other? It seems that many/most
newer gliders are Experimental. So I ask again, would it help me to
reclassify my ship as Experimental? If so, how complicated is it to
make the change?
Old October 21st 11, 02:58 PM posted to rec.aviation.soaring
bish
-John
(May 2011) manuals.
Happy soaring,
Lars Peder
Replace numbers with post1.tele.dk to answer by email- Masquer le texte des messages précédents -
- Afficher le texte des messages précédents -
DG gives you 3 days to refuse to pay then it charge you automatically.
This is illegal in Canada.
S6
Old October 21st 11, 03:03 PM posted to rec.aviation.soaring
bish
semi-trivial inexpensive part. *Any thoughts on conversion from
Standard to Experimental? *Does that help me in any way? *Or is there
Thanks, John
* I own a DG-101G ELAN. *If you look athttp://registry.faa.gov/aircraftinquiry/AcftRef_Results.aspx?Mfrtxt=&...
Standard or Experimental certified. *Was it common practice back in
the 80's to pick/choose Standard versus Experimental? *What was the
rational when choosing one over the other? * It seems that many/most
newer gliders are Experimental. *So I ask again, would it help me to
reclassify my ship as Experimental? *If so, how complicated is it to
make the change?
Last year I needed 2 part that cost 45 euros. They charge me 100
euros s/h and 245 euros for the annual contract.
400 euros for 2 rubber tube for my landing gear.
S6
Old October 21st 11, 03:07 PM posted to rec.aviation.soaring
Dan Marotta
Random comments to the above messages:
With Photo Shop, I can copy a page and insert my serial number.
Most folks I've talked to, regard Experimental as better than Standard as it
allows us to do a lot more things with our aircraft. I don't think it has
any effect on value, besides, these things are NOT an investment, they're
expensive toys.
I really wanted another (3rd) LS-6, but this crap convinced me to move on.
I'm now enjoying my LAK-17a...
Screw DG and all their horses.
"bish" wrote in message
-John
of
the German Aeroclub
us to
Certificate
new
(May 2011) manuals.
from
should
to
pay
own
(or
Happy soaring,
Lars Peder
S6
Old October 21st 11, 03:10 PM posted to rec.aviation.soaring
jcarlyle
It might be different in Canada than in the US. How is DG's "3 days to
pay" notification sent?
I never received anything by post or e-mail, the charge just appeared
on my credit card at the end of the month. A DG rep confirmed that DG
was renewing automatically without notification.
-John
S6
Old October 21st 11, 04:03 PM posted to rec.aviation.soaring
jcarlyle
John,
Going from Standard to Experimental for my old ASW-19 was very simple.
I needed to fill out an 8130-6 form, write a program letter, and then
have the FSDO rep check the actual airframe for serial number match
and display of the Experimental placard. It did not affect the resale
value in the slightest. The ease of the process might depend on your
FSDO, though.
As Dan said above, having an Experimental airworthiness allows us to
do more with our aircraft. That's why my LS8 is Experimental, even
though it's eligible to be Standard.
-John
Thanks, John
"For Claims Service Press 4" Mitchell Holman[_3_] Aviation Photos 3 July 6th 09 10:55 PM
"Stealth" Secret Service aircraft No Name Piloting 10 August 21st 08 12:12 AM
"Osprey Fire - Days Before Big Contract Awarded" Mike[_7_] Naval Aviation 0 April 18th 08 07:29 PM
Parker Service "letter" [email protected] Piloting 7 March 26th 08 11:32 PM
The Good, the Bad, the Ugly: AirGizmo PIREP, PS Engineering CD/Intercom woes, XM "service" Jay Honeck Owning 34 December 15th 06 03:02 AM
