Removing paint from windshield
Old June 1st 04, 07:47 AM
tony roberts
Default Removing paint from windshield
so - the continuing saga - after my glareshield fell off on takeoff (see
earlier post) a friend repaired it and remounted it. Then he noticed
that he had "missed" a few spots so he brought the aerosol of black
paint into the cockpit . . . well, you can guess the rest.
Does anyone know how to remove black paint spots from the windshield?
600 grade wet and dry paper was suggested by our local aircraft parts
supply house - sounds a bit extreme to me. I also tried lexan scratch
remover - GREAT product - available from any good Harley Dealer - great
on scratches that is - not too hot on paint.
Any ideas gratefully received
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Almost Instrument
Cessna 172H C-GICE
Old June 1st 04, 11:30 AM
Rip
RemovAll. It's a hydrogen peroxide based paint stripper, available from
Aircraft Spruce. Do a web search because it's also available in aerosol
cans for just the reason you mention.
Tony
Old June 1st 04, 02:07 PM
Stu Gotts
On Tue, 01 Jun 2004 09:30:24 GMT, Rip
I removed a lot of over spray on a windshield one using the
"ClearFix:" system, although it may be difficult to use on the inside.
And also try plain old isopropyl alcohol. D'Shannon recommends this
on their new replacement "glass" to remove excess proseal so don't
worry about harming the item.
A product that I use around the home is "Goo Gone". Works great, but
I haven't the slightest idea what it would do to the plexi.
Tony
Old June 1st 04, 02:15 PM
Rich
ABSOLUTELY
I had some overspray on my windshield. After many months I tried
alcohol. I was astounded to see how well it works.
Don't rush. Allow the alcohol to do its job. Rub gently with a series
of clean terry cloths. Above all, don't do further damage by using
paper towels or rubbing too hard. Just take your time and let the
alcohol do its work.
Rich
Tony
Old June 1st 04, 05:26 PM
G.R. Patterson III
If it hasn't been too long, a cotton rag soaked in mineral spirits or naptha will get
it off. I would try that immediately. If that doesn't work, buy some "Micromesh".
Start with the finest mesh in the kit. I would say that 600 grit paper is a recipe
for a new windshield.
George Patterson
None of us is as dumb as all of us.
Old June 1st 04, 05:55 PM
Michelle P
Tony,
The chemical solutions are the better way to go. If they do not work 600
paper will scratch the living daylights out of the windshield. Sounds
like they are trying to sell more products. If you use "sand" (abrasive)
paper then start with 2000 and move up to 4000 or 6000 if you can get it.
Michelle
Tony
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old June 1st 04, 07:18 PM
Gerald Sylvester
it off.
Napthalene? that is very very nasty stuff.
I'm definitely not an expert but I'd probably recommend not using
mineral spirits as it could damage the plastic ('glass'). Better
to use the 90% plus ethanol.
That is our procedure for cleaning my company's equipment. The
glare shield and especially my company's equipment takes tons of
radiation so any imperfection microscopically or macroscopically
could be bad.
Gerald
Old June 2nd 04, 02:32 AM
Al Gilson
In article nospam-A954F6.22495731052004@shawnews, tony roberts
Tony
My teenager.....oops...never mind...wrong question. Ya got me old friend,
(but I still have your hat).
Al Gilson
1964 172E
KSFF
Spokane, WA
Al Gilson
Spokane, WA USA
1970 VW Convertible
1964 Cessna Skyhawk
Old June 2nd 04, 12:01 PM
Bushy
Alcohol can cause acrylics (perspex) to craze. Something you won't like in a
windscreen, so if it's perspex (and possibly lexan) rather than glass, don't
use alcohol.
I used it on one of the perspex housings on one spark machine at work and it
does craze it!!!
Peter
Old June 3rd 04, 08:53 PM
Nigel T Peart
I have used 1200 paper with plenty of water, and then 'brasso' as a final
polish. Works great to
remove the fine scratches accumulated over 30 years. Hard work though.
"Al Gilson" wrote in message
Tony
Al Gilson
1964 172E
KSFF
Spokane, WA
Al Gilson
Spokane, WA USA
1970 VW Convertible
1964 Cessna Skyhawk
One coat paint for aluminum? [email protected] Home Built 10 September 17th 04 08:01 AM
Arrgh! I may have scratched my windshield! Peter R. Owning 7 April 28th 04 08:58 AM
paint shop recommendations wanted (SE) Stephen N Mills Owning 0 January 29th 04 04:44 PM
Radar Absorbing Paint robert arndt Military Aviation 2 December 2nd 03 06:09 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 03:51 AM
