Engine Analyzers
Old June 4th 04, 03:15 PM
M.E. Borner
Default Engine Analyzers
I am seriously thinking about installing an Engine Analyzer in my
plane and am looking at options. I think I have narrowed the choice to
J.P. Instruments or Electronics International. My mechanic has more
experience with JPI and feels their probes have a longer life. My
research has me leaning slightly towards EI for price, function and
design features. Really I am on the fence and am looking for something
substantive to sway me. If it matters, this will be installed in a
1999 Seneca V with Continental TSIO-360-RB (220HP Turbocharged)
engines. Does anyone have any experience, recommendations or
suggestions? Maybe I should do 1 of each (just kidding).
Old June 4th 04, 03:38 PM
Dave Butler
I don't have a dog in this fight, but there's this:
http://home.earthlink.net/~timrv6a/jpi.html
Dave
Remove SHIRT to reply directly.
Old June 4th 04, 05:09 PM
Kyler Laird
That's what convinced me to get a GEM (Insight). I've been quite
happy with it.
*Do* get an engine analyzer. They're a good investment. My plane
just came out of annual when I flew it to PJY last month. On the
descent, I noticed that both temps on one of my cylinders had
dropped.
With some great help from Michael, I learned that both plugs had
fouled. I'm sure I wouldn't have noticed it without the analyzer.
--kyler
Old June 4th 04, 04:10 PM
MikeM
I put a EI UBG-16 in my Skylane in 2000. (6 chts, 6 egts, oil temp,
bus voltage, alternator load current). Works great, no problems with
probes.
Biggest technical challenge was getting the brightness of the display
to track the main dimmer bus.
It sure shows what a ****TY job Cessna did when they "designed" the
cowling/baffling in my L model Skylane. I have improved the cht
balance greatly with some added baffling. Front two chts are still
40 deg F colder than the back four.
It also shows how POOR the mass-flow balance between the front and
rear cyclinders is on the Continental O470R. Due to the brain-dead
induction plumbing, the front two cyl get much less fuel/air than the
other four.
MikeM
Skylane '1MM
Old June 4th 04, 11:54 PM
M.E. Borner
Thanks for the info. Just as an off topic aside, are you based at
Westair at White Plains? That is where I am and I recall a Cessna 1MM
(white/blue/tan). Is that you?
MikeM wrote in message ...
probes.
other four.
MikeM
Skylane '1MM
Old June 5th 04, 12:42 AM
MikeM
Nope,
SLC, Ut
see: http://home.utah.edu/~mgm17160/OneMM.jpg
Old June 9th 04, 06:15 AM
Mark Mallory
Interesting, Mike. Where did you add the baffling?
other four.
How do you tell the difference between fuel/air QUANTITY and fuel/air RATIO?
Old June 10th 04, 05:26 AM
MikeM
Front two, 5&6 CHTs are too cold due to being blasted directly
with cold air via the intake scoops, (in addition to 5&6 having
the lowest EGTs, as discussed below). Cessna realized this, and
has made the scoop openings progressively smaller over the years.
(Also done for drag reduction).
I installed a "cold weather kit", which partially shields the
front two cyls from the direct air blast. It reduces the CHT
differenial between 5-3 and 6-4. When I started, the front
cyl ran ~300degF, now they are about 345.
The middle two, 3&4, were always the hottest, while
the back two, 1&2 ran cooler. I played with the baffles below the
cylinders, sealed all the holes in the air dam (surrounding
the magnetos), and stiffened the baffle silicone seals (used
stiffer 3/32 silicone instead of 1/16) and that reduced the CHT
differentials between 3-1 and 4-2.
other four.
RATIO?
I have never subscribed to the notion that the carburettor knows if
the air moving through it is destined for the front cylinders or the
rear ones. In other words, the mixture is established as the air
flows through the carb. Once mixed, there is a pretty big slug
of fuel/air sitting in the induction tubes waiting for the next intake
valve to open.
When an intake valve opens, the fuel/air mix is sucked into the
cylinder. The EGT is effected by the total volume
sucked in, (as well as the mix ratio). My EGTs have consistently been
hottest on the back two, 1&2, and lowest on the front two, 5&6; inversely
proportional to the length of the induction tubes between the carb
and the intake port. I believe that it is the flow resistance along
the induction tube that prevents cyl 5&6 from getting as much fuel/air
as 3&4 as much as 1&2. I dont see this distribution on Lycoming engines.
On Lycs, I attribute this to the carb being under the center of the
engine, and the induction tube lengths from carb to each cyl are more
equal...
I'd like someone to explain how the ratio of fuel/air can change
depending on which cyl is sucking? In other words, how could the front
cylinders be getting a different mixure ratio?
MikeM
Old June 4th 04, 06:06 PM
Michelle P
Hi,
I have had a Insight GEM in my Maule for the past nine years. no
problems with the unit. It did help me locate a bridged plug quickly though.
Michelle
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
