US Winching Sites
Old November 11th 11, 03:55 PM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Default US Winching Sites
We need examples of glider winch operations in the US at airports with
power traffic. Boulder comes to mind. Do readers know of other
locations?
Thanks
KS
Old November 11th 11, 04:12 PM posted to rec.aviation.soaring
Tony[_5_]
On Nov 11, 9:55*am, Karl Striedieck
locations?
Thanks
KS
Don at Cross Country Soaring at Fairbault, MN uses his winch on the
main runway at the public airport.
Old November 11th 11, 06:41 PM posted to rec.aviation.soaring
BobW
locations?
Thanks
KS
Boulder (CO) IS an example of a U.S. airport with (longstanding, since at
least 1976 in my direct exposure) parallel glider/power runways, but over that
time span has NEVER had winch operations to my knowledge.
Regards,
Bob W.
Old November 11th 11, 06:47 PM posted to rec.aviation.soaring
Frank Whiteley
On Nov 11, 8:55*am, Karl Striedieck
locations?
Thanks
KS
No winching at Boulder currently (yet).
From the winchdesign yahoo group.
May not be current or complete.
Notably missing
High Flights, Meadow Lake Airport, CO Hydrowinch
Colorado Spring East, modified Gehrlein
Rose City Soaring, Georgia
Cache Valley Soarnig, Logan, UT (engine upgrade in progress?)
Penn State Soaring Club, Mifflin, PA
Autotow included where applicable below.
"""Site Name""" """Winch""" """Autotow"""
Colorado Soaring Association\, Fort Collins\, CO Single drum\, 350cid
\, 4bbl No
Soaring Sooners Association\, Hinton\, OK Gehrlein single drum
(modified) Yes
Orange County Soaring Assoc.\, Hemet\, CA Gehrlein single drum yes
Los Alamitos CAP Self made two drum no
AGCSC\, Torrey Pines\, CA Roman design
29 Palms Soaring Club\, Twentynine Palms\, CA Gehrlein double drum yes
Permian Soaring Association\, Odessa\, TX Dual design\, single in use
\, 454cid no
Carolina Soaring Association\, Spartanburg\, SC homebuilt\, single drum
\, Ford 460cuin engine\, 310Hp occasionally
Philadelphia Glider Council\, Hilltown\, PA Dual Drum Eagle Winch
Prescott Soaring Society\, Prescott\, AZ Yes No
Finger Lakes Soaring Club\, Dansville\, NY Yes ?
VULTURES SOARING CLUB\, MARLETTE\, MI DREW\, Chev. 350\, Single drum
NO
Cross Country Soaring- Faribault\, MN Gehrlein
Wave Soaring Adventures- Toledo\, WA 253-380-8226 Gehrlein
Faultline Flyers\, Briggs\, TX No Yes
Greater Houston Soaring Assocation (GHSA) Yes\, retrofit of single
drum No (sold, no longer winching)
Sandhill Soaring Club\, Gregory\, MI TOST Model 04 Double Drum No
El Paso Soaring Society Yes No
Mohawk Soaring Club\, North Adams\, MA Yes No (status unknown)
Old November 11th 11, 07:02 PM posted to rec.aviation.soaring
Frank Whiteley
locations?
Thanks
KS
Notably missing
High Flights, Meadow Lake Airport, CO *Hydrowinch
"""Site Name""" * """Winch""" * * * """Autotow"""
Colorado Soaring Association\, Fort Collins\, CO * * * *Single drum\, 350cid
\, 4bbl No
Soaring Sooners Association\, Hinton\, OK * * * Gehrlein single drum
(modified) * * *Yes
Orange County Soaring Assoc.\, Hemet\, CA * * * Gehrlein single drum * *yes
Los Alamitos CAP * * * *Self made two drum * * *no
AGCSC\, Torrey Pines\, CA * * * Roman design
29 Palms Soaring Club\, Twentynine Palms\, CA * Gehrlein double drum * *yes
Permian Soaring Association\, Odessa\, TX * * * Dual design\, single in use
\, 454cid * * * no
\, Ford 460cuin engine\, 310Hp *occasionally
Philadelphia Glider Council\, Hilltown\, PA * * Dual Drum Eagle Winch
Prescott Soaring Society\, Prescott\, AZ * * * *Yes * * No
Finger Lakes Soaring Club\, Dansville\, NY * * *Yes * * ?
VULTURES SOARING CLUB\, MARLETTE\, MI * DREW\, Chev. 350\, Single drum
NO
Cross Country Soaring- Faribault\, MN * Gehrlein
Wave Soaring Adventures- Toledo\, WA 253-380-8226 * * * Gehrlein
Faultline Flyers\, Briggs\, TX *No * * *Yes
Greater Houston Soaring Assocation (GHSA) * * * Yes\, retrofit of single
drum * *No *(sold, no longer winching)
Sandhill Soaring Club\, Gregory\, MI * *TOST Model 04 Double Drum * * * No
El Paso Soaring Society Yes * * No
Mohawk Soaring Club\, North Adams\, MA *Yes * * No *(status unknown)
One more start up
Menomonie Flying Club, WI, sidewinder winch yes yes
Old November 11th 11, 09:52 PM posted to rec.aviation.soaring
Stephen[_3_]
locations?
Thanks
KS
Notably missing
\, 4bbl No
(modified) * * *Yes
\, 454cid * * * no
NO
One more start up
The Soaring Sooners Glider Club operates our winch off the Hinton
Municipal Airport main runway under agreement with the Airport
Manager. There is light power traffic in and out of the airport.
Stephen S9
Old November 11th 11, 11:47 PM posted to rec.aviation.soaring
Frank Whiteley
locations?
Thanks
KS
Notably missing
# High Flights, Meadow Lake Airport, CO *Hydrowinch
#Colorado Spring East, modified Gehrlein
#Rose City Soaring, Georgia
#Cache Valley Soarnig, Logan, UT (engine upgrade in progress?)
#Penn State Soaring Club, Mifflin, PA
Colorado Soaring Association\, Wellington\, CO * * * *Single drum\, 350cid
\, 4bbl No
#Soaring Sooners Glider Club\, Hinton\, OK * * * Gehrlein single drum
(modified) * * *Yes
#Orange County Soaring Assoc.\, Hemet\, CA * * * Gehrlein single drum * *yes
#Los Alamitos CAP * * * *Self made two drum * * *no
#AGCSC\, Torrey Pines\, CA * * * Roman design
#29 Palms Soaring Club\, Twentynine Palms\, CA * Gehrlein double drum * *yes
#Permian Soaring Association\, Odessa\, TX * * * Dual design\, single in use
\, 454cid * * * no
#Carolina Soaring Association\, Spartanburg\, SC homebuilt\, single drum
#Finger Lakes Soaring Club\, Dansville\, NY * * *Yes * * ?
#VULTURES SOARING CLUB\, MARLETTE\, MI * DREW\, Chev. 350\, Single drum
NO
#Cross Country Soaring- Faribault\, MN * Gehrlein
#Wave Soaring Adventures- Toledo\, WA 253-380-8226 * * * Gehrlein
#El Paso Soaring Society Yes * * No
#Greater Boston Soaring Club (MITSA)
#Shreveport Soaring
#Menomonie Flying Club, WI, sidewinder winch yes yes
Those marked with a # operate or have operated off of mixed use public/
private airports using main runways, taxiways, or adjacent surfaces.
Old November 12th 11, 01:45 AM
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
locations?
Thanks
KS
The folks down in Boerne, Texas have winch ops intermingled with power traffic.
Non-towered airport, Boerne Stage Field...5C1
http://www.5c1.net/sass.html
Dave White is the main instructor, good guy, can give you more info on their ops.
http://www.salsaaviation.com/aboutsalsa.html
Old November 12th 11, 06:35 AM posted to rec.aviation.soaring
On Nov 11, 10:55*am, Karl Striedieck
locations?
Thanks
KS
The Carolina Soaring Association is actively winching off the
Spartanburg Downtown airport (KSPA). We have mixed traffic - anything
from home-built single engine planes to business jets, helicopters and
anything inbetween. Works well so far.
Uli Neumann
'CSA's Winchmeister'
Old November 13th 11, 01:09 AM posted to rec.aviation.soaring
locations?
Thanks
KS
Uli Neumann
Today, about 8-10 business jets came into KSPA since there is a
republican presidential debate at a local college tonight, all while
we were winching. It works since we all talk to each other and the
winch launch announcements are being made on the unicom frequency.
Only once did I have to tell one of the jet-jock's to hold their take-
off since the line was not on the ground, yet.
Uli Neumann
Winching in Florida: Now! vaughn[_2_] Soaring 3 January 16th 10 11:35 PM
Winching in Florida this winter Don[_6_] Soaring 8 December 1st 09 08:23 AM
Winching - Cable danger. W.J. \(Bill\) Dean \(U.K.\). Soaring 9 March 27th 04 11:51 PM
Winching-Cable danger Andy Davey Soaring 0 March 23rd 04 03:32 PM
Winching: Steel vs. Plasma Bob Johnson Soaring 10 August 12th 03 05:41 PM
