GPS and airspace
Old June 26th 04, 03:45 AM
Marty from Sunny Florida
Default GPS and airspace
I've been using these marvelous GPS devices since the mid-1990's and am
astonished daily at their accuracy. I use microsoft Streets and Trips 2004
on a laptop for general travel, but need some method to overlay airspace and
aviation waypoints (similar to the info on a sectional).
Is there anything available, or can I somehow scan/import the sectional's
'data' into my laptop map? I have also purchased a couple of versions of
Delorme's Street Finder software, and a totally worthless Rand McNalley
mapping software.
Marty from Boiling hot South Florida (KLNA)
Old June 26th 04, 04:59 AM
Tom Jackson
Try Oziexplorer (www.oziexporer.com,) and scanned FAA sectionals provided by
Kyler Laird at aviationtoolbox.org.
The sectionals are "geo-tiffs" and Oziexplorer can import them and
automatically scale them to the proper lat/lon.
There are a few places to download aviation waypoints, such as
http://navaid.com/GPX/.
I've successfully loaded the waypoints and sectionals into Oziexplorer, and
the waypoints lie very nicely over the airports as depicted on the
sectional.
Works as a moving map, etc.
"Marty from Sunny Florida" wrote in message
and
mapping software.
Old June 27th 04, 03:31 AM
John Clonts
"Tom Jackson" wrote in message
newsw6Dc.95742$2i5.90727@attbi_s52...
by
Have you actually done this? It didn't work for me-- the georeferencing nor
the image display. I posted to the Ozi-Users email list and got the
response below.
I would sure like to get it to work, so if you have some tips please let me
know at jclonts AT hot DOT rr DOT com.
Cheers,
John Clonts
Temple, Texas
Date: Sun, 20 Jun 2004 19:05:18 -0000
Subject: GeoTiff support?
John,
There's more than 1 problem with what you're trying to do. Firstly,
the Geotiff tags for this image specify that the image is in Lambert
Conformal Conic projection and Ozi cannot (to my knowledge) handle
that projection on import. You can try to use Albers (equal area) as
an alternative, since it has the same set of required parameters.
That sometimes results in acceptable accuracy, but sometimes not
(this case). You can also manually calibrate the map image using the
just the upper left and lower right corners as cal points. You will
have to convert the lambert grid coordinates for the corners to
lat/lon or UTM first though, since Ozi doesn't allow specifying
coordinates in Lambert grid. That Ozi does not support Lambert
Conformal Conic projection on import, is the most glaring omission,
in an otherwise very capable program. That and the non-support of
any linear unit besides meters, for georef coordinates. Here's the
Geotiff dump of the georeferencing info for your image:
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0 0 0
250233 -715515 0
ModelPixelScaleTag (1,3):
128 128 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeProjected
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
GTCitationGeoKey (Ascii,8): "unnamed"
GeographicTypeGeoKey (Short,1): GCS_NAD83
ProjectedCSTypeGeoKey (Short,1): User-Defined
ProjectionGeoKey (Short,1): User-Defined
ProjCoordTransGeoKey (Short,1): CT_LambertConfConic_2SP
ProjLinearUnitsGeoKey (Short,1): Linear_Meter
ProjStdParallel1GeoKey (Double,1): 38.6666667
ProjStdParallel2GeoKey (Double,1): 33.3333333
ProjFalseEastingGeoKey (Double,1): 0
ProjFalseNorthingGeoKey (Double,1): 0
ProjFalseOriginLongGeoKey (Double,1): -100.583333
ProjFalseOriginLatGeoKey (Double,1): 38
End_Of_Keys.
End_Of_Geotiff.
Projection Method: CT_LambertConfConic_2SP
ProjFalseOriginLatGeoKey: 38.000000 ( 38d 0' 0.00"N)
ProjFalseOriginLongGeoKey: -100.583333 (100d35' 0.00"W)
ProjStdParallel1GeoKey: 38.666667 ( 38d40' 0.00"N)
ProjStdParallel2GeoKey: 33.333333 ( 33d20' 0.00"N)
ProjFalseEastingGeoKey: 0.000000 m
ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4269/NAD83
Datum: 6269/North American Datum 1983
Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left ( 250233.000,-715515.000)
Lower Left ( 250233.000,-792315.000)
Upper Right ( 352633.000,-715515.000)
Lower Right ( 352633.000,-792315.000)
Center ( 301433.000,-753915.000)
Now, to the obvious problem that you're seeing. I ran the image
through a tiffinfo utility and discovered the problem. Here's what
tiffinfo shows:
TIFF Directory at offset 0x15ff3e
Image Width: 800 Image Length: 600
Bits/Sample: 8
Sample Format: unsigned integer
Compression Scheme: None
Photometric Interpretation: RGB color
Samples/Pixel: 3
Rows/Strip: 10
Planar Configuration: separate image planes
Tag 33550: 128.000000,128.000000,0.000000
Old June 27th 04, 10:55 PM
Tom Jackson
I'm using version 3.95.3e of Oziexlplorer (commercial version, not demo.)
I download the TIF file from Kyler's website into a folder.
In Ozi, I choose file|Import Map|Single DRG (Or, all DRG . . .) It asks a
few questions, such as file location, etc. and automatically imports and
calibrates the image.
When I first got Ozi, it didn't work so I e-mailed them. Des, the creator,
e-mailed me back that he had updated the program to handle these types of
files, and that I should download the most current version. I did, and it
worked great. When I download waypoints (i.e., airports, using
http://navaid.com/GPX/) it shows them almost exactly on top of the ones
depicted on the map. Some are off slightly, but I don't use it for any real
navigation - just for fun.
I have actually used it a few times in the plane, works well as a moving
map. Will automatically pan from one sectional to the other, as I cross
boundries. The Terminal charts are also geo-referenced, and Ozi can import
them as well. Can draw routes, etc. or download them from the GPS. I use a
simple Garmin GPS III (not the Pilot version.)
"John Clonts" wrote in message
provided
by
nor
response below.
me
Cheers,
John Clonts
Temple, Texas
John,
Version: 1
Key_Revision: 1.0
Tagged_Information:
0 0 0
250233 -715515 0
128 128 0
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
GCS: 4269/NAD83
Corner Coordinates:
tiffinfo shows:
Bits/Sample: 8
Samples/Pixel: 3
Rows/Strip: 10
It's that Planar Configuration setting of "separate image planes"
that is confusing Ozi. Ozi wants to see "single image plane". As
Dave already pointed out, you can load and save the image using a
general purpose graphics editing program and that will correct that
situation. You will still need to take care of the projection
problem, one way or another, though.
J.G.
P.S. Here's the upper left coordinate in lat/lon:
N 31Deg 31Min 3.9Sec latitude
W 97Deg 57Min 13.1sec longitude
For the lower lower right, it's:
N 30Deg 47Min 50.2Sec latitude
W 96Deg 54Min 31.8Sec longitude
Old June 29th 04, 04:02 AM
John Clonts
Hello Tom,
Thanks for the tips. I found that when I use the "raw data" it does work as
you say (http://aviationtoolbox.org/raw_data/...onals/current/). Is
this what you are using?
But I have trouble when I try to use one of Kyler's "processed images" from
https://aviationtoolbox.org/Members/...s/map_explorer
I have the problems that J.G. diagnoses below.
Kyler, are you out there? does any of that make sense to you?
(The example that I was using was
https://aviationtoolbox.org/Members/...ols/map_image?
scale=50&image_format=GeoTIFF&lr_Y=-
792315.0&lr_X=352633.0&ul_X=250233.0&ul_Y=-715515.0)
Cheers,
John Clonts
Temple, Texas
N7NZ
news:KnHDc.190504$Ly.84959@attbi_s01...
creator,
real
import
a
provided
by
nor
response below.
me
Cheers,
John Clonts
Temple, Texas
John,
Version: 1
Key_Revision: 1.0
Tagged_Information:
0 0 0
250233 -715515 0
128 128 0
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
GCS: 4269/NAD83
Corner Coordinates:
tiffinfo shows:
Bits/Sample: 8
Samples/Pixel: 3
Rows/Strip: 10
J.G.
Old June 29th 04, 02:08 PM
Kyler Laird
"John Clonts" writes:
Bits/Sample: 8
Samples/Pixel: 3
Rows/Strip: 10
Ah ha! That was causing problems for ImageMagick too. I just didn't
realize that's what was doing it.
http://www.remotesensing.org/gdal/frmt_gtiff.html
INTERLEAVE=[BAND,PIXEL]: By default TIFF files with band
interleaving (PLANARCONFIG_SEPARATE in TIFF terminology) are
created. These are slightly more efficient for some purposes,
but some applications only support pixel interleaved TIFF
files. In these cases pass INTERLEAVE=PIXEL to produce pixel
interleaved TIFF files (PLANARCONFIG_CONTIG in TIFF
terminology).
So...I added "INTERLEAVE=PIXEL" and now tiffinfo reports this.
TIFF Directory at offset 0x580a1e
Image Width: 1600 Image Length: 1200
Bits/Sample: 8
Samples/Pixel: 3
Rows/Strip: 1
Planar Configuration: single image plane
ImageMagick displays a beautiful image now too.
Does that solve the problem you had?
Thank you for the report.
--kyler
