Inconol 713 required
Old December 31st 03, 07:36 PM
Martin
Default Inconol 713 required
I am building a gas turbine jet engine and need a small quantity of
Inconol 713 for turbine, 75mm diameter by 15mm thick. Does anyone know
of a supplier in the Uk that can provide me with what I need?
Thanks
Martin
Old January 2nd 04, 08:04 AM
Richard J Kinch
Martin writes:
Additional note: the material I am looking for may infact be "Inconel"
713.
For any US jet engine hobbyists, see my surplus metal stock (came from a
Pratt & Whitney jet engine parts subcontractor):
http://www.truetex.com/metals.htm
Old January 2nd 04, 03:39 PM
Richard Riley
On Fri, 02 Jan 2004 02:04:36 -0600, Richard J Kinch
:Martin writes:
: Additional note: the material I am looking for may infact be "Inconel"
: 713.
:For any US jet engine hobbyists, see my surplus metal stock (came from a
:Pratt & Whitney jet engine parts subcontractor):
: http://www.truetex.com/metals.htm
Martin, I don't find 713 anywhere but reference lists. Are you sure
718 won't do for your job?
Old January 2nd 04, 10:43 PM
Big John
Martin
Check model aircraft jet emgines. A number are made in UK. Also I
believe some are kit built.
You didn't say the size of engine you are building but some of these
model engines go up to 50 lbs thrust and may be derated to get down to
that thrust level???.
If you contact the companies who manufacture these jet engines they
may be able to help you find a source of metal for your project if
they don't have?
All the best.
Big John
Thanks
Martin
Old January 4th 04, 09:31 PM
Martin
Richard Riley wrote in message . ..
:Martin writes:
: 713.
I think 718 will do the job, do you know of anywhere in the UK which
sells small quantities if this?
Thanks
Martin
Old January 4th 04, 10:02 PM
Richard Riley
On 4 Jan 2004 13:31:33 -0800, (Martin) wrote:
:Richard Riley wrote in message . ..
: On Fri, 02 Jan 2004 02:04:36 -0600, Richard J Kinch
: wrote:
: :Martin writes:
: : Additional note: the material I am looking for may infact be "Inconel"
: : 713.
: :For any US jet engine hobbyists, see my surplus metal stock (came from a
: :Pratt & Whitney jet engine parts subcontractor):
: Martin, I don't find 713 anywhere but reference lists. Are you sure
: 718 won't do for your job?
:I think 718 will do the job, do you know of anywhere in the UK which
:sells small quantities if this?
I've found several in the states, nothing in the UK yet but I'm still
looking.
Pitts Special - info and photo's required. Darryl Gibbs Aerobatics 1 August 5th 03 08:05 PM
