Whelan Strobe Troubleshooting...
Old July 7th 04, 04:35 PM
zatatime
Default Whelan Strobe Troubleshooting...
Does anyone know how to go about trouble shooting a Whelan strobe
light? It is on a Piper Cherokee and is the "beacon" of the airplane.
I had an extra bulb I don't know the status of and swapped it out, but
still didn't get any emission. I'm thinking that its probably the
unit, but I don't know how to prove it since it isn't a continuous
power light.
There are 3 wires on the clip. A white, black, and red. I think the
red is what gives the pulse to the strobe and the black is ground of
course. The white has a sticker on it that says 13V so my assumption
is that that should be continuous power. Is my assumption correct?
If it is I know its the unit because I don't get any reading on the
meter when I connect to the black and white wires.
Is there somewhere I can look to get additional information? Any help
would be appreciated. At 350 dollars I'd like to be sure I'm
replacing the correct part and don't just need the 75 dollar bulb.
TIA for any responses.
z
Old July 7th 04, 05:42 PM
Ross Richardson
I had a similar problem and returned it to Whelan. They repaired the
power supply and returned it to me. Much cheaper than a new one and the
turn around was pretty quick. I called ahead to talk to service.
Ross
power light.
z
Old July 7th 04, 07:36 PM
zatatime
On Wed, 07 Jul 2004 11:42:29 -0500, Ross Richardson
Ross
Thanks. I got a quote of $150 to rebuild. They said about a week to
turn it around, so it looks like that's the right answer.
Thanks for the help.
z
Old July 7th 04, 06:18 PM
Jay Masino
light?
When power is applied to the power supply, you should hear a faint
whistle. If you don't hear the whistle, you probably have a bad power
supply (or you need to get your hearing checked ).
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old July 8th 04, 01:51 AM
EDR
In article , Jay Masino
light?
Or a bad capacitor.
Old July 8th 04, 06:30 AM
John
I do not remember the colors but of the three wires to the flash lamp:
wire A (red?) +450 VDC
wire B (black?) Ground
wire C (white?) 200 volt pulse to flash lamp trigger transformer
If you do not have over 400 volts DC to chassis on one wire the power
supply is bad.
There is enough 450 volt energy in the storage cap to kill you so be
careful.
On Wed, 07 Jul 2004 15:35:08 GMT, zatatime
power light.
z
Old July 11th 04, 04:19 PM
zatatime
On Fri, 9 Jul 2004 07:33:53 -0500, "David D Cowell"
Try searching for Whelen instead of Whelan
http://www.whelen.com
Well that sure did helped.
Thanks!
z
Strobe Recommendations??? Jim Weir Owning 8 March 11th 04 07:36 PM
Transponder/Encoder troubleshooting [email protected] Owning 6 August 27th 03 02:50 AM
Red lens for Hoskins Strobe wanted Terry Aviation Marketplace 0 August 6th 03 11:11 PM
Red lens for Hoskins Strobe wanted Terry Owning 0 August 6th 03 11:10 PM
Red Lense for Hoskins Strobe Wanted Terry General Aviation 0 August 6th 03 11:10 PM
