Info on Buying a Cherokee 180
Old July 15th 04, 03:57 PM
Brad
Default Info on Buying a Cherokee 180
I'm selling my Grumman AA1A to purchase a 1963 Cherokee 180. Aside
from the usual prepurchase stuff, I'm wondering if there are any
special things to watch out for on early model Cherokees.
Thanks!
(reply to brad@vision-technology and add .com at the end)
Old July 21st 04, 03:01 PM
Nathan Young wrote:
: Oil impeller pump AD.
: Wing spar attach SB. (dissimilar metal corrosion).
Also, the O-360 crankshaft corrosion AD if it's an A3A (hollow crank). There
are a couple of old AD's around that could be pricey too. Counterbalance tube on the
stabilator, and scissor linkages on the main gair. Grab hold of the stabilator at the
ends and see if there's any play in the bearings. I had to repace those on mine.
-Cory
* Cory Papenfuss *
* Electrical Engineering Ph.D. Graduate Student *
Old July 15th 04, 10:27 PM
Bob Noel
In article , zatatime
Having new torque links, and Ram Horn yokes saves you from 2
re-curring ADs. The yoke AD isn't bad,
It's kind of expensive to replace cracked yokes.
It'd also be good if the fuel line AD was taken care
of. It requires removing the tanks and replacing the fuel lines.
Always look for corrosion on the older models just to be safe. Can't
think of anything else off the top of my head.
HTH.
z
fuel line AD? Last I knew it was an SB, not an AD.
Bob Noel
Old July 16th 04, 04:35 AM
zatatime
On Thu, 15 Jul 2004 21:27:04 GMT, Bob Noel
Mine was done when I bought it. I thought it was an AD. I could be
wrong, but it'd still be nice to have done.
z
Old July 16th 04, 05:20 AM
The Weiss Family
"Brad" wrote in message
om...
Thanks!
Is your AA1A still for sale?
Adam
Old July 16th 04, 02:36 PM
John P
Just a note in passing...after checking a guy out in a 63 180 and having
flown a 65 180
it seemed like the 63 180 engine noise was greater.....could be me though.
John N3DR
"The Weiss Family" wrote in message
om...
Thanks!
Adam
Old July 16th 04, 06:04 PM
Nathan Young
I believe the exhaust stacks are different for the early 180s vs the
late 180s. My reference for this... Powerflowsystems.com makes
aftermarket exhausts and they reference their exhaust as working for
140s/160s and pre1964 180s.
-Nathan
On Fri, 16 Jul 2004 13:36:18 GMT, "John P"
flown a 65 180
John N3DR
om...
Thanks!
Adam
Old July 16th 04, 09:46 PM
Mike Spera
Check the glass thickness. Many old Cherokees out there with 1/8 inch.
Many upgraded to 1/4 inch.
Aside from the rear spar attachment AD, check if the main spar corrosion
SB was done.
Good Luck,
flown a 65 180
John N3DR
.com...
Thanks!
Adam
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION Don Owning 0 June 16th 04 05:14 AM
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION Don General Aviation 0 June 16th 04 05:13 AM
CHEROKEE NATIONAL FLY-IN & CONVENTION - THIS MONTH! Don Owning 0 June 3rd 04 05:03 AM
Cherokee National Fly-In & Convention - THIS MONTH Don General Aviation 0 June 3rd 04 05:01 AM
Cherokee National Fly-In & Convention Don Owning 0 May 5th 04 08:13 PM
