Wanted Info on Narco Com 810
Old July 18th 04, 04:07 AM
Default Wanted Info on Narco Com 810
Wanted Info on Narco Com 810 - i just installed a couple of Narco Com
810's in my D35 and the audio seems too low. i have connected to the
high output on the radio, but it still should be a little louder.
Is there a internal adjustment to hike up the gain?
Thanks Dave
Old July 18th 04, 12:20 PM
JFLEISC
Thanks Dave
If you are connected to 'speaker' output (pin N) you need to put a jumper
between pins 'J' and '6' (it states to do this if no audio panel is used). If
you are only using phones just connect to pin 'A'. I just went through all this
with my 810.
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer General Aviation 0 January 23rd 04 02:45 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Home Built 0 January 23rd 04 02:43 AM
Info for ELT910 NARCO gix Owning 0 December 30th 03 12:03 AM
SNS2 Guppy Info Wanted AKAVIE Home Built 3 October 1st 03 05:38 AM
WANTED: Narco Com 810 parts Gerrie Aviation Marketplace 0 August 12th 03 11:53 AM
