warped door in C172
Old August 11th 04, 10:59 PM
Default warped door in C172
The left door of my Cessna 172 is warped. I've tried the benign
options of using wooden blocks at appropriate places and applying
pressure to bend the door. But that didn't get the door back to where
it has a tight seal at the lower side (opposite hinges). There's still
about 1/2 inch gap between the door and the frame. Any ideas of what
else I can try?
Dale
Old August 12th 04, 01:22 PM
Land softer.
Sorry... couldn't help it... Seriously though, I think most planes of
typical GA vintage have lots of air leaks. If you were sucessful in bending the door
a bit with the blocks, maybe you can do better if you take it off and try it. I don't
know how troublesome that is for a 172, though. If you're just after wind noise and
it still closes OK, you could always band-aid it with thick rubber.
I'm sure Cessna would *love* to sell you a replacement door for a small,
nominal fee.
-Cory
: The left door of my Cessna 172 is warped. I've tried the benign
: options of using wooden blocks at appropriate places and applying
: pressure to bend the door. But that didn't get the door back to where
: it has a tight seal at the lower side (opposite hinges). There's still
: about 1/2 inch gap between the door and the frame. Any ideas of what
: else I can try?
: Dale
* Cory Papenfuss *
* Electrical Engineering Ph.D. Graduate Student *
Old August 12th 04, 04:48 PM
I must admit that never occurred to me. It might be warped. But I
doubt it because there are no wrinkles in the skin around the door.
C172 Air vents Matt Young Owning 8 July 2nd 04 12:53 PM
The warped world of airplane ownership Jay Honeck Owning 7 February 6th 04 11:19 PM
C172 Penn Yan 180 HP Engine Conversion John Roncallo Owning 4 October 20th 03 06:42 PM
wanted C172 Hankal Owning 0 September 23rd 03 01:23 AM
C172 / 5th Passenger stan Owning 1 August 3rd 03 10:46 PM
