Oil Temperatures
Old August 18th 04, 05:14 PM
Ross Richardson
Default Oil Temperatures
I have a Cessna 172F with the Lycoming O-360 conversion and a C/S speed
prop.
My oil temperatures are always low. I pulled the probe and place in in a
can of oil heated to 180 degrees and had a calibrated thermometer beside
it. I marked the meter in the plane so I know where this temperature is.
Even in the summer I cannot reach that temperature. I have the oil
cooler mounted on the back of the rear baffle on the port side of the
aircraft. It has run cool with the old engine and two years ago I
installed a factory overhauled engine. Any ideas why it stays so low.
Ross
Old August 18th 04, 09:51 PM
john smith
prop.
Where in the engine are you measuring the temperature?
Old August 18th 04, 10:18 PM
Darrel Toepfer
prop.
Hi Ross, can you give any details on who did and how much the
conversion cost?
We have this same airframe with the original O-300D and fixed pitch.
Thanks...
Old August 18th 04, 10:23 PM
Ross Richardson
The probe goes into the Lycoming spin on oil filter adapter.
Ross
prop.
Old August 18th 04, 10:31 PM
Ross Richardson
The plane came with the conversion. Really makes a C-172 fly. I have the
Bush (aka Avcon or Doyn) conversion. No support from Bush of Udall, KS;
I tried when I needed some information when I purchased the airplane.
Airplains and Penn-Yann also do conversions.
Pluses:
much better climb, somewhat more speed
Minuses:
This airframe does not allow (to what I can find) for a gross weight
increase
you still have 36 usable gallons in the tank and therefore shorter legs
if you push the engine. I usually fly at 60% and try to maintain a 4
hour no reserve burn. I plan for 2.5 hours, though.
Ross
prop.
conversion cost?
Thanks...
Old August 19th 04, 12:30 AM
Darrel Toepfer
Pluses:
Minuses:
increase
Thanks... Sofar we've replaced the wingtips with STOL versions and
its helped with takeoff and climb performance. Haven't cruised with
them yet (just finished it yesterday), but cruise performance before the
change was less than we had hoped for...
They helped the cruise performance of our C152...
Old August 19th 04, 01:55 AM
john smith
So long as the temperature of the oil returning from the engine is
around 230(?) degrees F, I wouldn't be too concerned. If it isn't
getting over 210, I would wonder if it was getting to all the places it
is supposed to get to.
Old August 19th 04, 02:20 AM
Mike Noel
As a cross check, you might try checking the sump oil temp immediately after
flying by dipping a long thermometer into the dipstick tube.
I have an O-360 A4A in my Archer with a very small oil cooler near the
bottom of the firewall. My problem until lately was too high an oil temp in
summer. At annual I asked my mechanic to check the vernatherm. He told me
it was OK. A bit later I pulled the vernatherm to look at it and saw the
seat on the plunger was not hitting the seat in the oil filter adapter
squarely. I had another mechanic install a new vernatherm and resurface the
filter adapter seat. The engine temperatures now look OK on summer
climb-outs.
I can't imagine my engine running too cold in the summer even with the
vernatherm stuck closed and routing all of the oil through the cooler. But
if it was stuck closed and the OAT was cool and I was running at 60% power,
it might happen.
Here is an interesting discussion of the factors affecting engine oil temp:
http://www.sacskyranch.com/eng18.htm
Regards,
http://mywebpage.netscape.com/amountainaero/fspic1.html
"Ross Richardson" wrote in message
prop.
Ross
Old August 19th 04, 03:19 AM
Newps
230 is way too high on a regular basis for oil going to the cooler much
less returning to the engine from the cooler. The generally accepted
number is 180 degrees at the point where most of us are getting our
readings from.
Old August 19th 04, 05:31 AM
Ross
I have a 172M with an O320E2D @1700 hrs TTSN with the same oil filter
system that likewise is cold blooded. My guess is that ours has very
little blowby as the oil also stays clean for many hours after a
change. It has been run mostly on MoGas, so the contamination load on
the oil is low. Does your oil stay clean unusually long too?
Have you tried covering part or all of the oil cooler?
Ours does not have a Vernatherm element installed in the oil filter
adapter - only a plug. Does yours?
My guess is you have a very good break-in. I don't think it is
something to worry about.
The justification for having the oil run above 180 degF though, is
that the dew point of the combustion products is about 180 degF.
Bonanza Engine Temperatures Peter Shurman Owning 1 July 11th 04 05:59 PM
Withstanding Peak Temperatures O. Sami Saydjari Owning 9 March 2nd 04 02:32 PM
Shock *Heating*? Jay Honeck Owning 48 February 25th 04 03:43 PM
