Cessna 172N with 0-320-H2AD
Old August 25th 04, 12:37 AM
Paul
Default Cessna 172N with 0-320-H2AD
I am looking for an a/c, my first, to complete my training and to use
for recreational flying. I am looking at 172s and a book I recently
acquired (The Cessna 172 by Bill Clarke) suggests that this engine is
to be avoided.
I saw an ad in Trade-A-Plane by Factory Engines and the prices for
factory remanufactured engines are as follows:
O-320-E2D - $16,652 (this engine is the predecessor to the H2AD)
O-320-H2AD - $19,301 (the engine in question)
O-320-D2J - $16,923 (the sucessor to the H2AD)
To me this is indicative of continuing problems.
What has been the expierience of owners of Cessna 172Ns with this
engine?
Paul
Old August 25th 04, 04:19 AM
Darrel Toepfer
engine?
That they'd really like an 0-360 with 180+ hp... ;-)
Extra ponies just make it fly like it should have, all along...
Old August 25th 04, 12:14 PM
Roger Long
This engine has a reputation for eating lifters and camshafts. We lost two
lifters and a camshaft at 1033 hours after purchasing a factory overhauled
engine and spent ten grand having the engine rebuilt. That really, really,
hurt.
I did an extensive amount of research on the lifter issue and set up a web
site to collect information. Here is what I concluded:
The early lifter problems that this engine had are not the same as it
currently experiences.
Other engines have lifter problems but lifter and cam failures are
significantly under reported in them. Lifter and camshaft damage can
progress to a startling extent before effecting performance. The performance
loss is so slow that pilots don't notice.
The H2AD has an AD that requires a check for metal that is optional on other
engines. A great feature of this engine is that the lifters can be pulled
and inspected easily. Therefore, when lifters spall, the problem is more
likely to be discovered. Other engines just go along quietly making metal
and wearing away their camshafts. Most take their worn camshafts to the
overhaul shop. A few fracture lifters or break cam shafts and stop running.
There were rampant metallurgical problems with lifters in the late 90's due
to the move to offshore outsourcing and labor/management upheavals. The FAA
will be coming out with a document about lifter problems late this year.
If you own one of these engines, you should have the lifters pulled and
inspected every second oil change. This will add about $2000 to the life
cycle cost of the engine but detecting a failing lifter early may save
removing your engine to split the case and replace a $3000 camshaft. You
should also probably put new lifters in about mid life which will add
another $1000 to the life cycle cost.
DO NOT buy a used O-320 H2AD, or any engine for that matter, without a
lifter and camshaft inspection. This will only take a couple hours with the
H2AD whereas other engines will need to have some cylinders pulled.
Make preheat your religion. Saying, "Just this once won't hurt." Can make
that $100 hamburger a $10,000 hamburger. We use an electric oil pan heater,
cowl blanket, and cowl plugs. Air head, for the length of time most FBO's
will run the heater, doesn't get the oil warm enough.
If you see a single flake of metal in your oil filter that sticks to a
magnet, especially if it is smooth on one side, PULL THE LIFTERS! Don't let
the A&P tell you that all mid life engines make some metal and you shouldn't
worry until it gets to a quarter teaspoon or so. That advice probably cost
us $10,000. After the first pinhead size piece comes out of a lifter, the
whole face come apart very fast and starts damaging the camshaft. Don't fly
the plane until the lifters are looked at.
There is a lot to like about this engine. It sends about twice as much oil
to the heads as other Lycomings and has a giant oil cooler. It runs very
cool and is not prone to valve problems.
Our engine runs very well between peak and 25 degrees LOP. All engines of
this class are prone to plug fouling so running very lean, even at the
expense of a hint of roughness, is important. For more, read:
http://baldeagleflyingclub.org/Manual.htm
The dual mag is delicate. Have it thoroughly inspected and adjusted every
500 hours, more often if anything in the engine performance changes. A good
reason for running very lean is that any problems such as induction leaks or
ignition adjustment drift show right up. Running ROP covers up a lot of
sins.
Every engine has its issues. This one may be somewhat more troublesome but
that is counter balanced by the ease of managing them. I've seen plenty of
spalled lifters in engines with mushroom lifters. It that case, you are
committed to an engine teardown. With the O-320 H2AD, it's only a two hour
job if you catch it before the camshaft is damaged.
It's a good engine for a plane flow by a lot of pilots because it is quite
hard to overheat the heads.
Roger Long
"Paul" wrote in message
m...
to be avoided.
engine?
Paul
Old August 26th 04, 01:08 AM
C Kingsbury
(Paul) wrote in message om...
engine?
I recently joined a partnership that's owned a 172N since new. One
partner, who entered the partnership three years into the life of the
plane said they went through two rounds of very serious engine work
(major-overhaul scale IIRC) very early in its life. It's now over 1800
on the tach (equal to ~2000 Hobbs) and the compressions are starting
to weaken but it's otherwise purred like a kitten for close to 20
years. My old CFII who owns a 172N also with plenty of hours on it has
suggested that he'd merely top it and reasonably look to get another
400-500 hours before majoring it.
We do 50-hour oil changes and send the oil for analysis at every one.
The plane is flown regularly in summer, intermittently the rest of the
year, though I think everyone is pretty careful about preheating.
Other than that I can't say it's been babied at all, except that it's
never been a trainer, which is saying something in a 172.
Lycoming joked that they'd never make an engine with the word "AD" in
it again. Overall I've never noticed any difference in values of 172s
based on this engine. My impression has been that it had a lot of
problems early on that have long since been addressed, though another
poster here had some interesting tips about ongoing maintenance I
haven't heard before. Worth looking into.
Broadly speaking the enduring value and popularity of every kind of
Skyhawk tells you something. If I was doing it again I'd look for a
180HP one with an autopilot and an IFR GPS and then I wouldn't have
gotten bigger-faster-plane-fever quite so quickly, perhaps. I'd also
look for a mid-time engine that's built its time over no more than 10
years. Of course, if I'd waited for that, I wouldn't own anything
right now as career changes made 1/5th of a 172 almost more than I can
afford.
Best,
-cwk.
Old January 20th 10, 11:56 AM
Colin Lake Colin Lake is offline
Junior Member
First recorded activity by AviationBanter: Jan 2010
I am not sure where to start with posting this request for advice. However on reading through your post I thought you may have received some worth while advice even though you initial posting was in 2004.
I have recently purchased a Cessna 172N with the 0-320-H2AD motor and it does not have the performance of my other C172 fitted with the 0-320-2ED motor. My question is it the 'H" motor that is causing this lack of performance and if it is, is it worth changing it to the 2ED motor??
to be avoided.
engine?
Paul
Old October 1st 10, 02:01 PM
knickick knickick is offline
Junior Member
First recorded activity by AviationBanter: Oct 2010
acquired (The Cessna 172 by Bill Clarke) suggests that this rebuilt engines is
to be avoided.
engine?
Paul
I have a good experience about the Cessna 172Ns. And it is working good.
Old November 3rd 10, 05:43 AM
playtimeover playtimeover is offline
Junior Member
First recorded activity by AviationBanter: Nov 2010
to be avoided.
engine?
Paul
There's no problem with the ad you saw. The ad will help you on what you are looking. I think there is other option on that ad, right?
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
FS: 1979 Cessna 172N, Worcester MA Dwight Ernest Aviation Marketplace 0 April 6th 04 03:59 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
