Owner replacement of Nav/Comm Radios
Old September 1st 04, 05:59 PM
endre
Default Owner replacement of Nav/Comm Radios
I am reading the FARs and am having a hard time figure out whether I
can slide out my old radios and have them upgraded and put them back
in. Slide in and out only no wiring or changing the shelf itself. Or
do I need A&P inspection?
Old September 2nd 04, 05:49 PM
Ross Richardson
How did you like the process and the radio. I am troubleshooting a Mk12D
problem now where the radio does not modulate, but has a carrier. It
finally works, after it warms up?. It never failed on the shop bench,
even with spray cooling and placing it in a refrigerator. I am going to
swap the two Narco Mk12Ds and see if the problem follow the radio or is
somewhere else.
endre wrote:
Thanks. Same basic radio. Had a Narco 12D upgraded by narco to 12D+.
Same weight same location.
(C Kingsbury) wrote in message . com...
(endre) wrote in message . com...
Weight & Balance is your main issue. AFAICT you're A-OK if you're
replacing like with like, but if you're making real changes that would
affect CoG, you at least need to get a new W&B signed off.
-cwk.
Old September 2nd 04, 05:55 PM
Paul Sengupta
"Ross Richardson" wrote in message
somewhere else.
Microphone wiring? Tray?
Paul
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
slide-in replacement for Cessna 300 series nav-com? Bill T. Owning 2 November 14th 03 10:47 PM
Narco MK 16 replacement SoulReaver714 Aviation Marketplace 1 September 23rd 03 04:38 PM
Nav/Comm for homebuilts question(s) Dave Gribble Home Built 3 August 29th 03 08:57 PM
