KNS-80/KNI-520 encoder bad?
Old September 6th 04, 06:45 PM
Default KNS-80/KNI-520 encoder bad?
OK... question for those in the know. I've got a KNI-520 connected to a
KNS-80 RNAV. The DME, localizer, and RNAV *distance* work fine, but the VOR needle
doesn't deflect properly recently. If you try to center it, it won't stay in the
center, but rather will twitch from pegged on one side to pegged on the other with a
very small (5 degrees) change in the OBS ring. I'm thinking that since the head
doesn't have a NAV converter, but rather tells the KNS-80 where the OBS is with
encoder lines, that one of those lines might be broken/intermittent. That would mean
it would think the head is in 1 of 4 (2?) positions, rather than somewhere in between.
Thoughts on this? Anyone fixed such a thing? I haven't torn into the wiring
yet and suspect it's intermittent (read: difficult to find).
-Cory
* Cory Papenfuss *
Mode C Indication Jeff Owning 9 May 5th 04 04:35 AM
FS: Narco AT-50A Transponder with ACK Encoder JR Home Built 0 April 29th 04 12:33 PM
Altitude encoder Chad Lemmen Owning 9 August 23rd 03 02:13 AM
