Piper PA-28 question
Old September 16th 04, 02:06 PM
GE
Default Piper PA-28 question
I recently purchased a 1973 Cherokee Charger. So far, I am really enjoying
the aircraft, but I have a question that has gone unanswered. There is no
mention of it in the POH or the information manual that I have.
Beneath the throttle quadrant but above the fuel selector (on the right
side), there is a knob that I am unsure about. This knob rotates and turns a
marker that indicates "L" or "R". I believe that this may be a trim for the
vertical stabilizer but I am unsure of how and when to use it.
I could be totally wrong, so any advice on this would be greatly
appreciated.
Old September 16th 04, 02:21 PM
OtisWinslow
Rudder trim. Use it to center the ball at cruise.
"GE" wrote in message
a
appreciated.
Old September 16th 04, 02:34 PM
Roy Smith
Assuming it works. From what I've seen of various Cherokees, as often
as not, they're pretty much inop. It connects into the rudder cable
system with springs. The springs eventually wear out or get out of
adjustment, and people tend not to bother fixing them.
Old September 16th 04, 02:53 PM
Marco Leon
Mine works but just *barely*. It takes quite a bit of turning to budge the
rudder. Can anyone give me an idea of how much the getting a new set of
springs will set me back? I hope it's not as ridiculous as the cylinders for
the seat vertical adjustment...
Marco
"Roy Smith" wrote in message
Old September 17th 04, 04:37 AM
vincent p. norris
rudder.
The trick is to give the knob a turn, then kick the appropriate
rudder pedal. Always works for me. I presume the kick ovecomes the
friction or "stickiness" in the system.
vince norris
Old September 17th 04, 02:36 PM
Marco Leon
Interesting. I'll have to give it a try. If it works, I'll owe you a cold
one!
Marco
"vincent p. norris" wrote in message
rudder.
vince norris
Old September 17th 04, 12:01 PM
Jay Masino
Hmmmm. That's weird. Mine is 37 years old, and it always seems to work
whenever I need to tweek it.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old September 21st 04, 12:02 AM
Robert
Those items are part of your annual. If they are not corrected then you need
to bring it up to you AP IA next time out so he will be sure to verify
proper rigging of your controls and possibly find corrosion has set in to
inhibit proper pilot adjustments. You never know how far these minor things
might become major.
"Jay Masino" wrote in message
--- Jay
__!__
Old September 16th 04, 02:47 PM
GE
Simple enough.
Do I turn it toward "L" if I want the ball to go left or is it opposite?
"OtisWinslow" wrote in message
enjoying
no
turns
a
appreciated.
Old September 16th 04, 03:03 PM
Paul Tomblin
Hold your foot on the rudder pedal to center the ball. Trim in the
direction of least resistance until there is no resistance. Release your
foot from the rudder pedal. It should now be trimmed.
"As Canadian as possible, under the circumstances"
A/D Question for Piper Cherokees zatatime Owning 6 June 11th 04 01:43 AM
Piper 6.00x6 Nose Wheel and Fork? mikem General Aviation 5 March 5th 04 11:34 PM
Piper Cub: "A Reflection in Time"... fine art print highdesertexplorer Aviation Marketplace 0 January 13th 04 03:47 AM
Piper Wheel Pants Question Brian Sponcil Owning 9 December 26th 03 05:47 PM
The Piper Cubs That Weren't Veeduber Home Built 5 August 28th 03 04:38 AM
