Upgrade Question
Old September 17th 04, 05:31 AM
tony roberts
Default Upgrade Question
Hi
I currently own a 172H and fly approx 150 hours per year.
Now considering a 180hp Comanche.
Anyone have any idea how much extra per year I should expect it to cost
(excluding fuel - that one's easy - just over 1gph extra)
Thanks
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old September 18th 04, 01:29 AM
Hi, Tony,
The two biggest increases will be in maintenance and insurance. I don't
have much Comanche experience but on our Arrow the extra cost for
maintenance of the gear and constant speed prop probably averages around
$600/year (much of which is for prop overhaul). But that cost is more than
offset by the lower fuel bills provided by the RG, compared to similar
performance FG airplanes. (175 hrs/yr X 3 gph savings X $3/gal = $1775/yr)
Insurance will be a problem until you have some number of hours in retracts.
Even after that, you will probably pay several hundred dollars/year more
for a Comanche compared to a 172.
I do have a couple of hours in a Comanche 180. It seemed a bit
underpowered. But it's book speeds are impressive, and it flies very
efficiently. Make sure its useful load will match your mission profiles.
-Elliott Drucker
Old September 18th 04, 01:33 AM
Al Gilson
Tony...Tony...Tony.....
Remember, everything in an airplane is $100. (or multiples of that
denomination)
Al
SFF
1964 172E
tony roberts wrote:
Hi
Thanks
Tony
Al Gilson
Spokane, WA USA
1970 VW Convertible
1964 Cessna Skyhawk
Old September 18th 04, 02:37 AM
Roy Smith
My club operates 3 Archers, 2 Arrows, and 2 Bonanzas. We're currently
charging $65/hr for the Archers and $75/hr for the 180 HP Arrow. Fuel
burn is essentially identical for both models, so the extra $10/hr is
accounted for by increased maintenance costs.
A buck or two is a higher per-hour engine reserve rate (IO-360 vs.
O-360). The rest is some mix of more complex systems (prop and gear)
which any Arrow owner will see, and generally higher repair costs
because our Arrow is older than any of our Archers. The latter is a
local effect, but offhand I don't know how much to attribute to that.
The Arrow probably costs more to insure, but that's not reflected in the
hourly rates, since it's a constant cost per month.
We adjust our rates every year so we just break even. We've got many
years, and many 10's of 1000's of hours of operating experience to go
on. Thus, I feel pretty good saying that a 180 HP Arrow should probably
cost about $5-10 more per hour to run than an Archer of similar age and
condition.
If e.drucker puts 100 hrs/year on his Arrow, his $600 figure works out
to $6/hr. I suspect he's overlooked that fact that his fuel injected
engine is more costly to overhaul, so he's lost sight of another couple
bucks/hr that he really should be accruing (at least on paper) against
an eventual overhaul or replacement. Overall, his figures and my
figures are in pretty good agreement.
Old September 18th 04, 03:37 AM
Bill
Check your insurance first.. I was going to upgrade to a Commanche and since
I have no complex time, I could not find insurance at any price. I was
told.. Buy and Arrow or a Mooney and get 200-300 hrs in it first.
Bill
"tony roberts" wrote in message
news:nospam-754895.21331416092004@shawnews...
Hi
Thanks
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old September 18th 04, 04:49 AM
We put an average of about 175 hrs/yr on the Arrow, so the extra maintenance
for RG and CS prop probably works out to under $4/hr. The $2/hr higher
figure for engine overhaul reserve is about right. However, with the price
of fuel so high (unless you burn mogas) the higher efficiency of the
injected engine probably almost makes this a wash.
Take care that in a more complex airplane it's maintenance and insurance
that are substantially higher. If you don't fly many hours per year, these
will really bite you.
-Elliott Drucker
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
