I'm looking into an early '60's vintage 182. I was wondering what people
had for real world numbers on cruise speed and fuel burn. And if anyone has any advice on particulars to look for during a pre-buy or anything else, that would be helpful also. Thanks! Chris |
Brinks wrote:
I'm looking into an early '60's vintage 182. I was wondering what people had for real world numbers on cruise speed and fuel burn. And if anyone has any advice on particulars to look for during a pre-buy or anything else, that would be helpful also. Thanks! A local '64 does 140 mph and 10 gallons per hour... |
Brinks wrote: I'm looking into an early '60's vintage 182. I was wondering what people had for real world numbers on cruise speed and fuel burn. And if anyone has any advice on particulars to look for during a pre-buy or anything else, that would be helpful also. Thanks! Cessna went to the big tail on the 182's for 1965, these are better on the wide bodies than the small tail 62-64 models. I have a 67 with big tires, VG's and no speed mods or wheel pants. I get about 128 kts TAS. I rarely indicate over 140 mph, it has to be pretty cold. You'll get about 11.5-12 gph in cruise above about 8000. As to what to look for... Engine and prop are standard items to look at. The engine mount needs to be inspected. That vintage of 182 has to have heat shields or the mount will corrode. Look at the firewall. Hopefully somebody after about 1968 landed it on the nosewheel and wrecked the firewall. Then if it was repaired right they will have put in the thicker firewall. This is very desirable. Look at the main gear attach points. If somebody lands really hard on the mains these can crack. Look inside the airframe for corrosion, especially the attach bolts and other hardware. You can total a 182 due to corroded fittings. Finally look at the tail attach point. There is a recurring AD to inspect the tail attach every 4000 hours. Look for leaking fuel from the bladders. If it's leaking it will be obvious under the wing and down the fuselage, you can't hide it. Everything else is nickles and dimes, relatively speaking. |
I get pretty close to book numbers...158 mph TAS in my stock 61 182 at
13.5 GPH per my JPI fuel flow monitor. It's in the paint shop right now so I expect to gain 15 - 20 mph with the new paint ;^) |
My '60 182-C regularly speeds along at 150mph and burns 12gph on average. These numbers go down & up respectively when my dogs stick their heads out the window. Dogs can fly. http://www.flyingmutts.com On Fri, 17 Sep 2004 19:05:53 -0500, "Brinks" wrote: I'm looking into an early '60's vintage 182. I was wondering what people had for real world numbers on cruise speed and fuel burn. And if anyone has any advice on particulars to look for during a pre-buy or anything else, that would be helpful also. Thanks! Chris |
| Thread Tools | |
| Display Modes | |
| Modern Inventions early Science 1900s airships FA | LindaBeynon | Aviation Marketplace | 0 | February 7th 05 01:41 AM |
| U.S. Nacy Null Numbers | David R Townend | Naval Aviation | 0 | September 2nd 04 05:57 PM |
| US Hull Numbers | David R Townend | Naval Aviation | 0 | January 26th 04 04:10 AM |
| 1930s Navy side numbers. | JDupre5762 | Naval Aviation | 3 | September 24th 03 08:51 PM |
| Early morning hotel-to-airport | Bob Fry | General Aviation | 21 | July 25th 03 06:51 AM |
