Piper Arrow IV fuel pressure
Old October 4th 04, 04:23 AM
MC
Default Piper Arrow IV fuel pressure
Does your fuel-pressure gauge fluctuate noticibly ?
Mine vibrates at about a 3Hz rate between the
middle and bottom of the green-band.
Engine runs fine...
Turning-on the electic pump reduces the amplitude of
the swing and stablizes it at around mid gauge.
Is this 'normal' ??
Old October 4th 04, 02:34 PM
Bob Chilcoat
The fuel pressure gauge on our '74 Archer is rock solid. So was the gauge
on the Arrow III I flew once, and on every other Cherokee I've ever flown.
I've never noticed fluctuation on the fuel pressure gauge. Don't ask me
about the load meter (ammeter), though.
Bob (Chief Pilot, White Knuckle Airways)
I don't have to like Bush and Cheney (Or Kerry, for that matter) to love
America
"MC" wrote in message
Engine runs fine...
Is this 'normal' ??
Old October 4th 04, 03:48 PM
Aaron Coolidge
MC wrote:
: Does your fuel-pressure gauge fluctuate noticibly ?
: Mine vibrates at about a 3Hz rate between the
: middle and bottom of the green-band.
: Engine runs fine...
: Turning-on the electic pump reduces the amplitude of
: the swing and stablizes it at around mid gauge.
: Is this 'normal' ??
Every Arrow I've ever flown (three different 180 HP versions) does this.
Don't know if it's bad or good, they were rental AC.
Aaron Coolidge
Old October 4th 04, 05:39 PM
PaulH
MC wrote in message ...
Engine runs fine...
Is this 'normal' ??
My 69 model does not fluctuate. Air in the line?
Old October 4th 04, 08:35 PM
Roy Page
Check the gascolator for a leak !
Had a similar problem on my Archer II.
In climb the fuel pressure gage fell back to midway between the red and the
center point of the green arc.
After leveling off the indicated pressure slowly came up.
With the electric pump on the variation was significantly less or stable at
higher indicated pressure.
I foolishly flew the bird halfway across the country like this.
Back at home, my AP found the gascolator top seal was unseated and leaking.
New seal fixed the problem - now have normal indicated fuel pressure with or
without the electric pump.
Normal for this and our club's Archer is needle in the center of the green.
Don't accept this varying pressure something is adrift.
Good Luck,
Roy
"PaulH" wrote in message
om...
MC wrote in message
Engine runs fine...
Is this 'normal' ??
Old October 5th 04, 05:15 AM
MC
I did the same thing. g (although in Oz it can be a long
distance between licenced mechanics.)
I too had a slight gascolator air leak on my last trek, (which made
for a somewhat lean mixture), but the fluctuating pressure predates
that problem for several inspection cycles.
om...
MC wrote in message
Engine runs fine...
Is this 'normal' ??
Old October 5th 04, 12:20 AM
This sounds like something that needs immediate attention. My guess would
be a leaking (or otherwise faulty) engine driven fuel pump or possibly a
leak in the gascolator.
On our Arrow IV, the fuel press gauge is stable in the middle of the green.
It moves just a bit (to higher pressure) when the electric pump is turned
on.
I think in your case a visit to the A&P is definitely in order. The good
news is that the problem is most likely not going to be terribly expensive
(in aviation terms) to fix.
Please let us know what you find.
-Elliott Drucker
Piper Arrow electric fuel-pump MC General Aviation 7 June 3rd 04 02:50 AM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
Fuel dip tube for Piper Warrior? TTA Cherokee Driver Owning 16 May 3rd 04 05:42 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
