Hello,
Has anyone ever purchased or use this tow from www.dragger.com? Spruce sells it as well. I need to push an aircraft up a small slope. I'm concerned that this product would try a pull/push UNDER the nose wheel if too much resistance is against the plane. It doesn't take too much to lift the nose of most small aircraft. If you have any input about this product, I would appreciate it. Thanks |
I am part owner of one. While I don't have much of a slope to contend
with, I don't think it will be a problem. I've started to push my Cherokee Six a couple times with the parking brake set, and all it does is lurch. If it was going to be a problem, I would expect to see it in this instance as well. You do have to be careful with wheel pants though, it is not naturally balanced and tends to rock so that the handle goes down before you get it fastened around the wheel. that can chip up the lower edge of your wheel pant. If it is being used on several different planes, it can be a pain to keep adjusting for different nosewheel sizes. All and all, it isn't bad and serves its purpose. AXA wrote: Hello, Has anyone ever purchased or use this tow from www.dragger.com? Spruce sells it as well. I need to push an aircraft up a small slope. I'm concerned that this product would try a pull/push UNDER the nose wheel if too much resistance is against the plane. It doesn't take too much to lift the nose of most small aircraft. If you have any input about this product, I would appreciate it. Thanks -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
NoseDragger Dragger | AXA | General Aviation | 1 | October 7th 04 09:30 PM |
