Is anyone aware of statistical or other data that would indicate what
	percentage of engines make it well beyond the factory specified TBO, and how much longer they can be flown safely? I worry about sudden engine failure due to metal fatigue. Many of the small Lyc. engines have a TBO of around 2,000 hours. My O-320-D3G (TBO 2,000hrs) has now 2,200 hrs since new, it's never been opened for any reason. Of the above time, 1,100 hrs have been flown in my RV-6. I change oil (15W50) and full-flow filter every 50 hrs, cut-open the filter for inspection, and have the oil analyzed. The compression is still in the mid-70s. I plan to continue flying until any of oil analysis/compression/oil consumption would indicate a noticeable departure from their historic values. But the one other thing I worry about is the matter of metal fatigue, which would not be indicated by any of the factors that I am observing, but which could lead to engine stoppage. If you have any data to support using these engines past their TBO it would be much appreciated.  |
| Thread Tools | |
| Display Modes | |
| Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy | Paul | Home Built | 11 | December 26th 04 04:24 AM |
| Metal fatigue in Lycoming engines limiting its TBO? | Wolfgang | Home Built | 11 | November 7th 04 02:46 PM |
| Lycoming engines "code" | Philippe | Home Built | 3 | September 11th 04 03:25 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
