Garmin GPS 90
Old November 12th 04, 06:01 AM
bd
Default Garmin GPS 90
I have a GPS 90 that doe not work. It powers up and seem alright
except for the fact it doesn't pick up satelites. Anybody know if
there is a reasonable fix for this without spending an arm and leg
with Garmin?
Old November 13th 04, 03:06 AM
Roy Page
You can do a total reset, clear and restart by holding down the page key as
you switch the GPS 90 on.
This will clear the almanac data and start the unit clean. It may take up to
15 minutes to find the satellites and get a new almanac data.
Try that procedure, if it doesn't work then there is another combination of
keys upon start which will put it into a diagnostics mode where each
function can be checked. Let me group know and I will describe how to get
into the diagnostic mode.
Roy
N5804F - PA28-181
"Roy Smith" wrote in message
with Garmin?
There is a "cold start" mode which makes it do a full reset, you might
want to try that. I forget exactly how to get into that mode, but it's
on the same page where you can set "battery saver" mode.
The receiver uses the last fix it had as a starting point to converge on
a new fix. If you power it up a long distance from where you powered it
down last, or a few other possible scenarios, the stored last fix will
be bogus and sometimes this confuses the receiver and makes it hard for
it to lock onto a signal. The cold start mode makes it throw away any
stored fix information and start from scratch. It might take as long as
15 minutes to converge on a new solution when you do this.
It may not work, but it's simple enough to do and doesn't cost anything
to try. I've had to do that once or twice with my Garmin-90.
Old November 13th 04, 08:16 AM
J. Severyn
"bd" wrote in message
om...
with Garmin?
It could be a bad antenna. It is a passive printed circuit spiral antenna,
soldered to the BNC connector. Borrow another antenna, either passive or
active, as the 90 supplies 5v to the BNC for powering an active gain antenna
(just a antenna with an amplifier in the antenna module).
If it is the antenna, crack yours apart and resolder the printed circuit
foil to the BNC (usually where it fails). It is fairly simple to fix if you
are handy with a small soldering iron.
J. Severyn
KLVK
Old November 14th 04, 06:39 PM
Nigel T Peart
I had a similar problem. Went to the fresh start mode, took about 45 mins,
but eventually
found the sats.
Unlikely it's bust.
"J. Severyn" wrote in message
om...
with Garmin?
antenna, soldered to the BNC connector. Borrow another antenna, either
passive or active, as the 90 supplies 5v to the BNC for powering an active
gain antenna (just a antenna with an amplifier in the antenna module).
you are handy with a small soldering iron.
J. Severyn
KLVK
Install a Garmin GNS430 or an "Apollo" GNS480 ? Roy Page Owning 23 October 26th 04 03:52 PM
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 10:03 AM
Garmin Specials ADV Michael Coates Home Built 0 March 18th 04 01:24 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 03:04 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 10:04 PM
