clearview inline air filter
Old November 21st 04, 05:07 PM
Mike Noel
Default clearview inline air filter
I want to protect my vacuum instruments with a filter between the vacuum
regluator and the (dry) vacuum pump on my 74 Archer. Spruce sells the
Clearview for about 50 bucks, and sells the filter plus mounting hardware
and STC for about 85 bucks. Does anyone have any experience with this or
other inline filters? I'm guessing the the extra 35$ is for the STC and a
couple of clamps.
Regards,
http://mywebpage.netscape.com/amountainaero/fspic1.html
Old November 23rd 04, 05:45 PM
Bruce Cunningham
"Mike Noel" wrote in message ...
couple of clamps.
Yep, got one ready to install now. It's just the filter, two hose
clamps, and a couple of ty-wraps. The $30 or so is for the STC that
comes with it. Installation is simply to cut 4 inches of vacuum hose
out of the line between the pump and the regulator valve and insert
the filter.
Regards,
Bruce Cunningham
N30464
Old November 24th 04, 02:06 AM
Doug Vetter
couple of clamps.
I installed a clearview filter last year after troubleshooting a vacuum
system gremlin. My experience, in short, is that installing an inline
filter of any kind between the vacuum pump and the regulator is just
good common sense. Call it cheap insurance.
The clearview filter indeed works as advertised...it can be easily
inspected and replaced on condition. As you surmised, you need to buy
the $85 kit first and get the STC signed off by an IA, and then you can
replace the filters with a logbook entry.
I wrote an article about the installation process that applies to this
part and parts like it. Click through:
Aviation - Articles - Maintenance - FAA/PMA Parts, STCs, and 337's.
Hope this helps.
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
K&N Performance Gold Oil Filter? MikeremlaP Home Built 0 September 3rd 04 05:58 PM
K&N Air Filter tony roberts Owning 3 May 31st 04 05:26 AM
Filter element for Frantz filter Philippe Owning 1 April 20th 04 08:23 PM
where exactly to put the noise filter Dico Reyers Owning 25 February 25th 04 03:21 AM
Airwolf oil filter system kevin Owning 3 August 7th 03 04:24 PM
