It took more than a month, but my 206 is finally flying again after getting
the wing skin replaced. A line guy had towed it into a flagpole. They did not have to make any modifications and everything is just as it was before. We ended up replacing the whole leading edge assembly rather than peel the leading edge off the false ribs and then bond a new skin to them. It was probably a lot cheaper in the long run, plus doing it the other way would have required cutting two new inspection holes. Most of the time was spent on all that riveting, especially toward the back of the wing. Matt said he didn't even have to learn any new swear words to fix it. (I think he knows them all anyway.) -- Christopher J. Campbell World Famous Flight Instructor Port Orchard, WA Ne Obliviscaris |
Well, congratulations. Must feel good getting it flying again.
Doug |
On Sat, 18 Dec 2004 12:20:52 -0800, "C J Campbell"
wrote: It took more than a month, but my 206 is finally flying again after getting the wing skin replaced. A line guy had towed it into a flagpole. They did not have to make any modifications and everything is just as it was before. We ended up replacing the whole leading edge assembly rather than peel the leading edge off the false ribs and then bond a new skin to them. It was probably a lot cheaper in the long run, plus doing it the other way would have required cutting two new inspection holes. Most of the time was spent on all that riveting, especially toward the back of the wing. Congrats. It must be great to get it back again! Did you end up painting the plane or just the new wingskin? |
C J Campbell wrote:
It took more than a month, but my 206 is finally flying again after getting the wing skin replaced. Out of curiosity, what did you do for flying during that month? - Andrew |
"Andrew Gideon" wrote in message online.com... C J Campbell wrote: It took more than a month, but my 206 is finally flying again after getting the wing skin replaced. Out of curiosity, what did you do for flying during that month? - Andrew As a flight instructor, I spend most of my time in other airplanes anyway. It mostly affected my ability to do high performance instruction and charter. |
"Nathan Young" wrote in message news ![]() On Sat, 18 Dec 2004 12:20:52 -0800, "C J Campbell" wrote: It took more than a month, but my 206 is finally flying again after getting the wing skin replaced. A line guy had towed it into a flagpole. They did not have to make any modifications and everything is just as it was before. We ended up replacing the whole leading edge assembly rather than peel the leading edge off the false ribs and then bond a new skin to them. It was probably a lot cheaper in the long run, plus doing it the other way would have required cutting two new inspection holes. Most of the time was spent on all that riveting, especially toward the back of the wing. Congrats. It must be great to get it back again! Did you end up painting the plane or just the new wingskin? Just painted the new wingskin. We had to work a little bit to get the color to match, but it looks pretty good. |
| Thread Tools | |
| Display Modes | |
| Bush finally admits it! | noname | Military Aviation | 1 | August 6th 04 12:31 PM |
| I can finally read... | Wizard of Draws | Instrument Flight Rules | 2 | June 27th 04 04:00 PM |
| Finally, some real solo IFR practice! | Guy Elden Jr. | Instrument Flight Rules | 0 | April 15th 04 04:55 AM |
| finally got my Instrument Rating in Kansas | Bob Gardner | Instrument Flight Rules | 10 | April 1st 04 10:54 PM |
| It’s finally ready! | Joern Lillehagen | Home Built | 0 | September 4th 03 03:11 AM |
