Garmin - Jeppesen Flitestar Connection
Old January 17th 05, 02:56 PM
gwengler
Default Garmin - Jeppesen Flitestar Connection
I know this has been discussed here before but I'm still not able to
connect my Garmin III Pilot to the Jeppesen FliteStar program I have
on my laptop. The problem of course is the serial-USB adapter which I
have to use since modern laptops do not have old style serial
connections anymore. If someone has been successful, what exactly was
the configuration (COM, baud rate, format [Garmin or NMEA for example]
etc.) and which was the *exact* serial-USB adapter being used?
Gerd
Old January 17th 05, 04:04 PM
Dave Butler
Don't know about FliteStar, but I emailed Garmin tech support and they told me
what I needed to do to connect using my USB/serial adapter. It seemed to be a
FAQ for them.
Old January 17th 05, 04:43 PM
My modern Toshiba still has a serial port. I have several Garmin GPSes
and they all drive FliteDeck just fine.
I think with USB it is especially important that the GPS be connected and
running before you open FliteDeck. Once the GPS is connected make sure it
appears as a USB device in Device Manager. Without that, there isn't a
chance it will work.
Gerd
Garmin - Jeppesen Flitestar Connection gwengler Instrument Flight Rules 3 January 18th 05 02:04 PM
Garmin 296 and FliteStar Rich Raine Owning 11 June 18th 04 06:57 AM
Garmin 295 and Flitestar F.Pardi Aviation Marketplace 0 April 19th 04 12:11 PM
FS: Jeppesen Skybound II - Garmin Jon Hicks Aviation Marketplace 0 March 13th 04 01:13 PM
Jeppesen FliteStar - Africa Jack Methven General Aviation 0 August 23rd 03 10:08 PM
