Autopilot pitch problem
Old January 27th 05, 03:52 PM
Jim Burns
Default Autopilot pitch problem
We've got an S-Tec 60-2 in our Aztec. After sitting out in a heavy pounding
rain last summer, we started experiencing run away pitch problems. I found
an S-Tec news letter that says this can happen when water gets into the
static system and the transducer can't read the proper static pressure. It
says to remove the static line from the transducer, cap it, and fly the
airplane with cabin static pressure going to the transducer to see if the
problem goes away. No problems have been noted with any of the pitot/static
instruments.
Has anybody had this happen? Does anybody know what the transducer looks
like? Obviously it's attached to a static line, and S-Tec says that it
should be mounted in a warm dry place, but I'm wondering what I should look
for.
Thanks
Old January 27th 05, 03:57 PM
Steve
pounding
pitot/static
instruments.
look
for.
Thanks
Look at http://www.s-tec.com/pdf/SYS60-2.pdf. It's the little blue round
thingy.
Old January 27th 05, 04:39 PM
Jim Burns
Thanks. Now I just need to find where it's mounted.
Old January 28th 05, 12:28 AM
Javier Henderson
"Jim Burns" writes:
Find the static ports dedicated to the a/p pressure sensor, then follow
the tubing.
-jav
Old January 28th 05, 02:28 PM
Jim Burns
That brings up a great question... Will there be a static port specifically
dedicated to the pressure transducer, or could the line going to the
pressure transducer simply be T'd into the instrument static tubeing? I'm
hopeing that it is a dedicated source/line, because it would simplify
matters if we indeed find water in the line.
Thanks
"Javier Henderson" wrote in message
"Jim Burns" writes:
the tubing.
-jav
Old January 28th 05, 04:22 PM
Javier Henderson
"Jim Burns" writes:
I have owned two airplanes with S-Tec autopilots, on both cases there
were two static ports dedicated to the a/p.
-jav
Old January 28th 05, 08:26 PM
Juan Jimenez
The answer to that question usually depends on whether the a/p was factory
equipment, or an add-on...
"Jim Burns" wrote in message
specifically
Thanks
"Jim Burns" writes:
the tubing.
-jav
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
Propellor pitch ... Bob Noel Owning 2 July 29th 03 04:30 AM
