This is a second attempt at producing an HDR image of an aircraft in flight.
As the saying goes....there's more than one way to... I've "discovered" two techniques whereby it is possible to create an HDR image of an aircraft in flight. The second of the two is much easier and produces similar results to the first method..... 1 Take a photo of the aircraft in flight in RAW format. Make sure your exposure is SPOT on. 2 Process it out as a JPG. 3 Process it out as a JPG with +1 exposure. 4 Process it out with -1 exposure. 5 OPTIONAL: you could create many different layers depending on your wish to experiment simply by altering the exposure adjustment each time you render it out as a JPG. 6 Use Photomatix to combine the layers. Since the software thinks that each layer is identical, specify the exposure spacing between the layers. 7 Adjust the various options to create what suits you in an HDR and render it out. DONE! |
![]() "Canuck" wrote in message ... This is a second attempt at producing an HDR image of an aircraft in flight. As the saying goes....there's more than one way to... I've "discovered" two techniques whereby it is possible to create an HDR image of an aircraft in flight. The second of the two is much easier and produces similar results to the first method..... 1 Take a photo of the aircraft in flight in RAW format. Make sure your exposure is SPOT on. 2 Process it out as a JPG. 3 Process it out as a JPG with +1 exposure. 4 Process it out with -1 exposure. 5 OPTIONAL: you could create many different layers depending on your wish to experiment simply by altering the exposure adjustment each time you render it out as a JPG. 6 Use Photomatix to combine the layers. Since the software thinks that each layer is identical, specify the exposure spacing between the layers. 7 Adjust the various options to create what suits you in an HDR and render it out. DONE! Interesting. I wonder if one could achieve the same effect by boosting the highlights and shadows separately in post processing. Cheers, Indrek Aavisto -- Criticism is easy; achievement is difficult W.S. Churchill |
On Fri, 10 Jun 2011 00:30:49 -0500, Canuck wrote:
3 Process it out as a JPG with +1 exposure. 4 Process it out with -1 exposure. This does nothing to increase the dynamic range. Oversaturated highlights and underexposed shadows will remain exactly the same. At the very best, this method could be called pseudo-hdr. In actuality, it is pure malarkey. |
On 6/10/2011 7:44 PM, Indrek wrote:
Interesting. I wonder if one could achieve the same effect by boosting the highlights and shadows separately in post processing. Cheers, Indrek Aavisto That's exactly what I do using Capture One. In fact, they have sliders just for highlights & shadows. |
On 2011-06-10 18:33:51 -0700, Chris Richardson
said: On Fri, 10 Jun 2011 00:30:49 -0500, Canuck wrote: 3 Process it out as a JPG with +1 exposure. 4 Process it out with -1 exposure. This does nothing to increase the dynamic range. Oversaturated highlights and underexposed shadows will remain exactly the same. At the very best, this method could be called pseudo-hdr. In actuality, it is pure malarkey. For a single exposure pseudo-HDR, single exposure tone-mapping using a piece of software such as NIK HDR Efex Pro to tone-map the single exposure, rather than making the RAW ACR adjustments, would result in a far more satisfying result. My suggestion would be to download the demo copy of NIK HDR Efex Pro and see for yourself. https://www.niksoftware.com/hdrefexpro/usa/entry.php -- Regards, Savageduck |
"Indrek" wrote in message
... "Canuck" wrote in message ... This is a second attempt at producing an HDR image of an aircraft in flight. As the saying goes....there's more than one way to... I've "discovered" two techniques whereby it is possible to create an HDR image of an aircraft in flight. The second of the two is much easier and produces similar results to the first method..... 1 Take a photo of the aircraft in flight in RAW format. Make sure your exposure is SPOT on. 2 Process it out as a JPG. 3 Process it out as a JPG with +1 exposure. 4 Process it out with -1 exposure. 5 OPTIONAL: you could create many different layers depending on your wish to experiment simply by altering the exposure adjustment each time you render it out as a JPG. 6 Use Photomatix to combine the layers. Since the software thinks that each layer is identical, specify the exposure spacing between the layers. 7 Adjust the various options to create what suits you in an HDR and render it out. DONE! Interesting. I wonder if one could achieve the same effect by boosting the highlights and shadows separately in post processing. Cheers, Indrek Aavisto -- Criticism is easy; achievement is difficult W.S. Churchill No. The HDR software does something differently.....and depending on the other settings you use, it can produce an image that is quite different than just adjusting the shadows and highlights. Nick |
"Chris Richardson" wrote in message
news ![]() On Fri, 10 Jun 2011 00:30:49 -0500, Canuck wrote: 3 Process it out as a JPG with +1 exposure. 4 Process it out with -1 exposure. This does nothing to increase the dynamic range. Oversaturated highlights and underexposed shadows will remain exactly the same. At the very best, this method could be called pseudo-hdr. In actuality, it is pure malarkey. Nope. If you have a look at the original image and compare it to the HDR image, there is quite a difference. Yeah, it is pseudo - hdr......but doing it the real way is a total pain in the arse because more often than not the aircraft is not travelling in a very stable path and having to shoot with a shutter speed of 2000 and above limits you to very bright days. Still....it can be done the real way or this way. The results are not that dissimilar. N. |
New 18m Class ship - First Flight - The JS1 starts proving flight phase | [email protected] | Soaring | 2 | December 14th 06 02:06 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey | Dave Vioreanu | Owning | 0 | April 22nd 05 02:55 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey | Dave Vioreanu | Piloting | 0 | April 22nd 05 02:55 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey | Guy Elden Jr | Piloting | 0 | April 21st 05 04:37 PM |
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? | Scott Ferrin | Military Aviation | 0 | April 3rd 04 08:47 PM |
