New 747-800 Escape Slides
Old July 3rd 11, 09:38 AM posted to alt.binaries.pictures.aviation
Diesel[_3_]
Default New 747-800 Escape Slides
Received this in the post today.
Here is a very interesting picture of the new 747-8I with the new Air
Cruisers door 1 and upper deck escape slides deployed. We are currently
doing FAA repeatability testing on this airplane, which requires five
deployments from each door using the same slide. We are about half-way
through the tests but have to wait until late next week to finish up since
the airplane is now being prepared for it's Paris Air Show fly-in on June
20th.
The upper deck slides are a new and unique patented design that features the
arch tubes. Traditional slides use many large cross tubes and tension straps
on the bottom of the slide to give it beam strength. Beam strength prevents
the slide from buckling under the load of evacuating passengers. In this
case the slide needs to hold several thousand pounds and not buckle. This
slide is over 45-feet long. The typical arch bridge type construction
provides the necessary beam strength for a large slide at less weight and
reduced pack volume.
Good view of the racked wing tips too.
Old July 3rd 11, 11:39 AM posted to alt.binaries.pictures.aviation
Diesel[_3_]
Sorry, I should have added. Photographer unknown.
"Diesel" wrote in message
u...
20th.
straps
prevents
Old July 4th 11, 10:16 AM posted to alt.binaries.pictures.aviation
Alan Erskine[_4_]
20th.
WOW! Considering the length of the upper units, the curved sections are
probably to keep the slides rigid. Still, looks like a walk bridge over
a small stream.
Old July 5th 11, 02:53 AM posted to alt.binaries.pictures.aviation
Avsec
"Alan Erskine" wrote in message
ond.com...
20th.
straps
prevents
a small stream.
Remember seeing Qantas doing a test on B747 at the Mascot Jet Base a few
years back and the LAMEies sticking different coloured tape on the apron. I
asked what was that all about and was told they were laying bets as to where
the slide would end up when deployed. More exciting than two flies on a
wall.
Avsec
Gliding lecture slides Richard Lancaster Soaring 22 April 20th 10 02:30 AM
USN & USAF 1940/50s glass slides pkstore2 Piloting 0 May 26th 05 10:10 AM
FA: A-10 and F-14 slides THE RIPPER Aviation Marketplace 0 August 26th 04 06:37 AM
Rod Machado PPL Slides For Sale Curtis Instrument Flight Rules 0 December 13th 03 05:48 AM
Rod Machado PPL Slides For Sale Curtis Products 0 December 13th 03 05:48 AM
