Garmin 196 simulator mode
Old July 22nd 03, 02:43 AM
John Bell
Default Garmin 196 simulator mode
The 196 will automatically follow the route. However, you can manually
steer right and left using the left right on the touchpad in addition to up
and down for speed.
I have some info about navigating using the GPS at www.cockpitgps.com.
--John Bell
Old July 22nd 03, 01:07 PM
Dennis O'Connor
'Tis in the manual...
Denny
"Martin Hellman" wrote in message
om...
I recently got a Garmin 196 and was having trouble figuring out how to
get it in "flying" simulator mode, that is you appear to be moving,
not at rest (which is easy). I even did a search on the on-line
version of the user manual on all occurrences of "simulat" and none of
the references to simulator or simulate said how to do it. Though it
did say you should practice simulating flights before taking it in the
cockpit! Well, Garmin tech support told me how to do it and here is
the answer. (I also did a google search and nothing turned up on the
subject, so I hope this is new info.)
"After the unit is in the simulator mode, press the page button until
you get
the nav screen which is the screen right after the map. Press the up
arrow
key to adjust the speed."
Hope this helps others.
Martin
Garmin 430 Reception Jon Kraus Owning 16 November 7th 04 03:17 AM
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 09:03 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
