WAAS question -- altitude accuracy?
Old September 20th 03, 09:39 PM
Craig Davidson
Default WAAS question -- altitude accuracy?
Jay Honeck wrote in message ...
How accurate is GPS for determining altitude, now that WAAS is active?
I was in the air over five hours yesterday, and while droning along found
that our new AvMap's altitude readout was just about dead-nuts accurate --
it was maybe 50 feet off, at times.
In fact, due to the constantly changing barometric pressure along our route
of flight, there were times when I might have trusted it before my
altimeter.
Anyone know how precise it is now?
Jay, The FAA seems to say 3 meters vertical throughout the majority of the
continental U.S. and portions of Alaska:
http://gps.faa.gov/Programs/WAAS/waas.htm
But the site below says 6 meters (95 percent of the time) with a worst case
of 15.7 meters.
http://users.erols.com/dlwilson/gpswaas.htm
Here are some more interesting sites:
http://waas.stanford.edu/old_metrics.html
http://www.edu-observatory.org/gps/dgps.html#WAAS
Old September 20th 03, 10:54 PM
David L. Wilson
accurate --
route
altimeter.
case
of 15.7 meters.
Beat me to replying with my link. Note the FAA site does not say if it is
quoting 95%, 50% or what. As my measurements are now a little old, I will
be making new ones soon. But today I will be cleaning up after not so nice
a lady (Isabelle).
Old September 20th 03, 11:38 PM
bob mologna
I was on top of Lugnaqilla mountain in Ireland today and the GPS (Meridiam
Plat) put it at 925 - 924 metres. The topo puts it at 925. Just lucky
maybe...
"Craig Davidson" wrote in message
.net...
accurate --
route
altimeter.
case
of 15.7 meters.
Old September 23rd 03, 02:19 AM
steve
Doesn't the GPS give you 'altitude' -- computed as height above the
surface of an ellipsoid? Or does it correct for mean sea level? There
seem to be several computations required to derive true altitude from
the raw GPS altitude coordinate and it is not clear to me if particular
GPS receivers perform this adjustment.
(I would hope that an aeronautical GPS receiver would perform this
adjustment!) As for my decidedly non-aeronautical-non-WAAS-enabled
Magellan 410 GPS, it rarely correlates very closely to known altitude
benchmarks when I try it, even with many satellites 'locked.' God help
anyone who attempts a precision approach with my GPS!
Steve
maybe...
.net...
accurate --
route
altimeter.
case
of 15.7 meters.
Old September 23rd 03, 02:35 AM
David Megginson
steve writes:
particular GPS receivers perform this adjustment.
I think that most of them use WGS84, which is a little more complex
than a simple ellipsoid.
All the best,
David
Old September 23rd 03, 03:09 AM
David L. Wilson
"David Megginson" wrote in message
steve writes:
Some models (Garmin's included) display orthometric (above the geoide or
roughly above mean sea level) by using a look up table for the geode height,
and some other models display the ellipsoid altitude.
Old September 23rd 03, 05:42 AM
Frank Looper
"David L. Wilson" wrote in message
t...
steve writes:
height,
And it should also be injected into this thread that Delta won't be doing
blind approaches with SP IIIs. As has been pointed out in many, many
threads, there's GPSRs, and there's GPSRs, and that second set has 2 or
three more zeros on the end.
Frank
Old September 23rd 03, 02:52 PM
Mike Rapoport
"Frank Looper" wrote in message
Frank
The accuracy is the same though.
MU-2
Old September 23rd 03, 03:58 PM
Dale DePriest
Most do but some do not. The computation required to derive true
altitude is not complex but requires a table of data that can be very
large. The math is simply to interprolate between table locations and
provide a simple addition or subtraction to the ellipsoid altitude. You
can determine if your receiver does this by looking at the NMEA data.
Check my web site for an article on how to decode this information. You
can compare the computed value with the accurate data that is avaialbe
on government web sites to see how good the table is.
Dale
_ _ Dale DePriest
/`) _ // http://users.cwnet.com/dalede
o/_/ (_(_X_(` For GPS and GPS/PDAs
Old September 23rd 03, 08:43 PM
Frank Looper
k.net...
doing
Frank
MU-2
There are a number of people who would disagree with you on that, and most
likely not just folks who sell those five figures units, but their customers
and others as well.
Frank
Question: Velocity/Cozy and high altitude Shin Gou Home Built 6 February 16th 05 02:03 AM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Question: DP altitude vs MCA/MEA Doug Easton Instrument Flight Rules 7 April 7th 04 03:29 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
