Delcom Air 960 wiring
Old January 17th 12, 09:06 PM posted to rec.aviation.soaring
Bob Walker
Default Delcom Air 960 wiring
Our club has a Delcom Air 960 panel mounted in a Schweizer 2-33. Currently
we are using a speaker-mike which jacks into the front of the radio. We
would like to wire the radio with a speaker and two microphones. Does anyone
know if this configuration is possible with this radio? If so, could you
provide a wiring diagram. Any help will be greatly appreciated.
Bob Walker
Old January 18th 12, 05:57 PM posted to rec.aviation.soaring
On Jan 17, 3:06*pm, "Bob Walker" wrote:
Our club has a Delcom Air 960 panel mounted in *a Schweizer 2-33. Currently
Bob Walker
The only real trick to wiring as you outlined is the fact that these
mikes are electret. This means that an aircraft mike (carbon
equivalent) might not work. However the standard Radio Shack electret
will work. You have to figure out the PTT and install PTTs and mike
wiring to each stick to both turn on the ptt and connect the proper
mike.
I had made this very setup in my 2-22 and I used gaming headsets with
out the speaker although you could use a speaker in the glider.
I think that you will find the small mike jack has a ring tip and
sleeve arrangement like a standard mike jack. the ring would normally
be the mike ant the PTT would be the tip. The sleeve would be ground.
The speaker is the larger plug and just goes to the speaker leads.
You can buy a manual from Delcom for $25.00. At least a while ago they
sold an adapter for standard headsets. This may well mean that you can
use a standard aircraft mike setup as the radio provides the
exicitation for the electret mike.
JDB
Old January 18th 12, 06:27 PM posted to rec.aviation.soaring
Mike Gatfield
Was just about to do the same! haven't tried these but seen similar on
other sites:
http://www.delcom.com.hk/externalmicjack.html
Currently
anyone
Bob Walker
Old January 18th 12, 08:12 PM posted to rec.aviation.soaring
other sites:http://www.delcom.com.hk/externalmicjack.html
Currently
anyone
Bob Walker- Hide quoted text -
- Show quoted text -
Use the quoted diagram and wire the two mikes parallel at the jack.
The PTTs and individual miles should be separate circuits and come
together at the jack.
when you key the mike that mike is "hot" and the transmitter is turned
on.
I had something like this for my old 2-22 radio.
I couldn't remember if the PTT was separate and went to the tip or
like shown. I bet for the drawing above.
JDB
Old July 23rd 16, 04:36 AM posted to rec.aviation.soaring
Bob Walker
can i here the opp with this and what frequencu is it i live in elliot lake ontario canada
please and thank you
Delcom 960 Panel Mount....... [email protected] Aviation Marketplace 0 June 27th 06 03:17 AM
Delcom-960 headset adaptor needed Ron Aviation Marketplace 3 April 18th 06 01:13 AM
Delcom Battery Mike Soaring 5 April 7th 06 03:11 AM
Delcom Battery Mike Soaring 1 July 25th 05 05:22 PM
Need panel mount for Delcom Radio Mark Lenox Soaring 3 June 24th 05 03:31 AM
