Driving sheet-metal screws into 4130
Old January 23rd 04, 02:59 PM
Grandpa B.
Default Driving sheet-metal screws into 4130
Greetings, all.
I'm restoring a Champ, and have a question about driving screws into a
drilled 4130 tube.
If I drill the proper sized hole, the screws refuse to 'take'; they simply
give up their threads to the harder metal of the tube. If I over-size the
hole, then the screw won't hold diddley (that's a technical term).
Do I just keep driving fresh screws until one finally makes it in? I've
tried both stainless and cad-plated 'pk' types.
Another related question: These screws are going into a structural tube -
the windshield pillar, in this case. The original design from Champion
appears to have been thus. Is there a danger here, other than opening the
tube to moisture and corrosion? I am making an 'extra' hole, by the way.
And, unfortunately, I can't weld it up, since the fabric and interior are
done, and the hole is through the fabric, and right next to the headliner.
Jon B.
Sheet metal "Nibbler" Nolaminar Home Built 3 January 24th 04 07:05 AM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 08:08 PM
