Position recorders for badges
Old February 29th 12, 03:10 AM posted to rec.aviation.soaring
fredblair
Default Position recorders for badges
Are there any activities underway to grant approval for the Position
Recorders like the flywith CE recorder to be used for badges. They
have been approved in Australia, Canada and the UK. It seems that
they GPS altitude would be proof enough of 'no landings'.
Fred
Old February 29th 12, 03:54 AM posted to rec.aviation.soaring
Marc
Recorders like the flywith CE recorder to be used for badges. *They
have been approved in Australia, Canada and the UK. *It seems that
Fred
Position recorders can already be used for Silver and Gold badges, as
approved by ones NAC. The SSA, to my knowledge, has yet to formally
approve any position recorders. GPS altitude is not currently
acceptable as evidence, if the a position recorder is capable of being
approved as an electronic pressure recording barograph, then it may be
used on its own. Otherwise, a separate barograph must be carried, and
that data also provided. There is a proposal in front of the upcoming
IGC plenary session to allow use of GPS altitude, if approved (it's in
year 2 stage), I believe it could go into effect as soon as the next
Sporting Code update in October...
Marc
Old February 29th 12, 04:12 AM posted to rec.aviation.soaring
Tony[_5_]
Fred
approved by ones NAC. *The SSA, to my knowledge, has yet to formally
approve any position recorders. *GPS altitude is not currently
used on its own. *Otherwise, a separate barograph must be carried, and
that data also provided. *There is a proposal in front of the upcoming
Marc
The SSA has approved the FlywithCE position recorder for silver and
gold badges. You still have to have a barograph for altitude though.
Old February 29th 12, 03:25 PM posted to rec.aviation.soaring
Papa3[_2_]
Fred
Fred,
As others have posted, we approved FlyWithCE as a GPS Position Recorder last year. As others have also noted, the current IGC Sporting Code requires a traditional barograph be carried as well. As a result, there have been very few badge flights documented using this method (IIRC only one or two flights total).
Erik Mann
SSA Badge and Record Committee
Fred
Position Recorders allowed the US for Silver badges? Bastoune Soaring 15 September 22nd 11 01:45 AM
CFI-G and Badges, racing glider[_2_] Soaring 14 March 3rd 10 03:45 PM
Diamond Badges Nyal Williams Soaring 8 November 27th 06 06:08 AM
Badges ? ... We don't need no stinkin' badges Doug Snyder Soaring 36 September 21st 05 08:26 AM
First badges 2005 Marfa, TX Burt Compton Soaring 0 January 2nd 05 02:28 PM
