Converting LXN log files to IGC with Windows 7 64-bit
Old March 27th 12, 05:21 AM posted to rec.aviation.soaring
2NO
Default Converting LXN log files to IGC with Windows 7 64-bit
The "conv-lxn.exe" application I previously used to convert .LXN files to .IGC does not work with 64-bit Windows. I was unable to find any kind of upgrade or update at http://lxnavigation.si/.
I am BACK IN THE AIR and have no way to prove it!
~ted/2NO
Old March 27th 12, 08:32 AM posted to rec.aviation.soaring
Max Kellermann
Try this one:
http://max.kellermann.name/download/...el/lxn2igc.exe
I have reverse engineered it a few years ago to have something for
Linux, but since now Windows people can't run DOS programs either, it
might be helpful for you, too.
It's a command-line program, not so user friendly, sorry. Copy it to
the directory that contains the LXN files, open a command prompt
there, and type:
lxn2igc the_file_name.lxn
Please give feedback if that works. I think I have never tried it on
Windows.
(Yes, it also runs on Linux and Mac OS X and any other operating
system. Ask me if you need that. It's free software, the source code
is available.)
Max
Old March 27th 12, 10:39 AM posted to rec.aviation.soaring
Max Kellermann
Tim Newport-Peace ] wrote:
I notice the each record in the generated file ends CR/CR/LF instead of
CR/LF and this may upset some viewers.
Also, the generated file fails integrity checks, so cannot be used for
Badges/Records/OLC.
Is this only due to the CR/CR/LF problem, or is the G record wrong?
Please drop me an email with a sample file.
Max
Old March 27th 12, 10:54 AM posted to rec.aviation.soaring
Open the LXN file in SeeYou then Ctrl+S or File Save as IGC and you're done.
IGC file will even validate just fine after this procedure.
Andrej Kolar
glider pilots use
http://www.Naviter.com
~ted/2NO
Old March 27th 12, 10:27 PM posted to rec.aviation.soaring
Max Kellermann
Thanks for the test file; I have uploaded a new version of my lxn2igc
program with a fix for this problem:
I can't remember where I put my copy of VALI-LXN, please see if this
version fixes the validation problems.
MAx
Converting CAI 2 IGC 4 OLC GliderPilot Soaring 4 April 11th 11 06:27 AM
Converting GPS info [email protected] Piloting 9 March 14th 06 02:36 AM
Converting non-US certificate to US Roy Smith General Aviation 10 September 28th 05 06:48 PM
need help w/converting Mustant II AI Nut Home Built 5 November 17th 04 02:31 PM
Converting the Baron to turbo DeltaDeltaDelta Simulators 0 March 20th 04 07:29 PM
