Goddard Cable Problem
Old April 2nd 12, 04:10 PM posted to rec.aviation.soaring
Peter von Tresckow
Default Goddard Cable Problem
I was in the process of upgrading my panel with my new to me Tasman
V1000/FP10. The vario did come with the Goddard Oudie connection cable (ps5a
i think), and it was working fine at first, but now I am just seeing
jibberish being transmitted when I go into terminal mode in see you on the
Oudie. I have tried the Naviter cable, and the FP10 is working correctly as
that cable transmits the data without issue.
Did I possibly fry my goddard cable???
Thanks
Peter
Old April 2nd 12, 04:29 PM posted to rec.aviation.soaring
cfinn
If it's jibberish, I would expect you have a mismatch in the data
rates between the devices.
Thanks
Peter
Old April 2nd 12, 04:54 PM posted to rec.aviation.soaring
vontresc
That was my initial thought as well. I tested the FP10 with my desktop and a serial cable, and all was well at 4800/8/n/1.
The interesting thing was whan I tried the goddard cable with Condor on my PC, I got the same jibberish coming through on the oudie cable.
Thanks
Peter
Old April 2nd 12, 05:35 PM posted to rec.aviation.soaring
cfinn
Did you check the settings on the Oudie? I still think it's a speed
problem. You've tried two sources and have the same results with the
Oudie, and the FP10 works OK with the PC.
Thanks
Peter- Hide quoted text -
- Show quoted text -
Old April 3rd 12, 02:29 PM posted to rec.aviation.soaring
Paul Remde
"Peter von Tresckow" wrote in message
Thanks
Peter
Hi Peter,
The Goddard Oudie-PS5a-1 cable works fine with the Tasman FP10 - as long as
you have the version of the FP10 that provides 5V power for the PDA. There
are 2 versions of the FP10 - One provides 5V power and the other does not.
The connections on the FP10 are identical to the connections on the Goddard
PS-5a and Cambridge 302, etc. If you have the version of the FP10 that
doesn't provide 5V power, that would explain the issue. The Goddard
Oudie-PS5a-1 cable has a built-in RS-232 voltage level converter which must
be powered with 5 V.
The Naviter Oudie power/data cable must be powered with 12V to work.
Otherwise, when you see gibberish, it probably means that the baud rates are
not matched. Make sure you have the same baudrate set at the PDA and FP10
and GPS.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old April 3rd 12, 03:20 PM posted to rec.aviation.soaring
Paul Remde
Hi Peter,
When you connected the Oudie-PS5a-1 to the PC, was it powered with 5V? It
must be powered with 5V for the RS-232 voltage level converter to work.
Best Regards,
Paul Remde
"vontresc" wrote in message
news:28911584.1000.1333382053976.JavaMail.geo-discussion-forums@ynlp3...
(ps5a
as
Thanks
Peter
Old April 3rd 12, 04:02 PM posted to rec.aviation.soaring
Peter von Tresckow
The FP10 does supply the 5V for the PDA, and I did check that it has power.
I plugged my desktop into the FP10, and was able to receive serial data from
the GPS (4800-8-n-1). I hgave also played with every conceivable baud rate
setting on the Oudie, and still no joy. I fear I may have fried the Max232
ttl converter :-(
Pete
"Paul Remde" wrote in message
Hi Peter,
Best Regards,
Paul Remde
a
(ps5a
correctly
as
Thanks
Peter
Old April 4th 12, 06:24 PM posted to rec.aviation.soaring
Sean Fidler
I had a bad Goddard PS5a-1 cable for the first few days of the Uvlade contest last year. The dealer was insistent that it could not be the cable. When a replacement cable was finally shipped after day 3 or so and tens of hours of trying to find a software configuration or other problem...the system immediately fired up. So the cable was actually bad. Now I hear of another problem with the same cable...so it is the beginning of a trend perhaps?
The new Goddard PS5a-1 cable (shipped mid Uvalde) worked flawlessly for me during the fall and is for sale now that I have sold my LX5000. If interested in a discounted and barely used replacement, please give me a call.
Sean
F2
smfidlerATgmailDOTcom
Thanks
Peter
Oudie for sale, Goddard PS5a-1 cable for sale Sean Fidler Soaring 3 April 3rd 12 02:51 PM
Goddard PS-5a Brad[_2_] Soaring 1 February 19th 10 04:07 AM
Goddard Cables & Power supply FS Discus 44 Soaring 0 February 1st 07 05:48 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
