http://www.ssa.org/files/member/b%26rguide.pdf
Old April 10th 12, 11:55 PM posted to rec.aviation.soaring
Gregg Leslie[_2_]
Default http://www.ssa.org/files/member/b%26rguide.pdf
Really,
Try understanding this...
Old April 11th 12, 03:25 AM posted to rec.aviation.soaring
Tony[_5_]
On Tuesday, April 10, 2012 5:55:39 PM UTC-5, Gregg Leslie wrote:
Really,
I've found that reading the sporting code first helps.
Old April 11th 12, 04:15 AM posted to rec.aviation.soaring
Darryl Ramm
Really,
Yes start with the FAI Sporting Code Section 3, and really read and understand it. It is a rich/complex set of rules, so be careful and use the provided precise definitions for terms, swapping in their exact meanings every time you come across those terms--dont' just assume what things loosely mean. Not doing that will just lead to confusion. Then once you have a understanding of the rules then read the FAI pilot/OO guide (sporting Code Section 3 Annex C) and then read the SSA guide you linked to.
You also should find a good official observer to work with and discuss the rules, tasks, issues etc. with them well before the flight. Spend time trying to find an OO who really knows the rules. If you did not use an OO then you'll have already missed the possibility of many of the possible claims for this flight.
You and your OO should also read the IGC approval documentation for your flight recorder, and make sure to follow any requirements there.
Commonly made useful advice for any flights that require a declaration is to use a paper declaration done so that it overrides any electronic declaration--there are just too many possible problems with electronic declarations to not use paper, at least as a back-up. This is pointed out in the SSA document and has been discussed on r.a.s. before.
Darryl
Old April 11th 12, 11:41 AM posted to rec.aviation.soaring
David Reitter
Doesn't the last declaration override anything else?
Which means that the logger needs to be switched on early, before the paper declaration is signed. -?
Old April 11th 12, 04:59 PM posted to rec.aviation.soaring
Darryl Ramm
Technically its when the electronic declaration is entered vs. when a paper one is signed/dated/timed by the OO. Some (older) flight recorders are brain dead and will rewrite the declaration timestamps or clobber the declarations in existing flight logs if you do the "wrong thing" so in general power them on and don't touch anything after entering your declaration. paper vs. electronic has been covered here before and the recommended steps are covered in the SSA guide. World records are different and require a electronic declaration (and suitable level approval for the flight recorder).
Darryl
Old April 12th 12, 02:08 AM posted to rec.aviation.soaring
I can attest that Rolland Hasness has added "friendly" back into the badge process. The Badge Dude will do everything he can to award a badge if the flight meets the requirements. Also, he will accept the IGC file and application via email. If he does not like the electronic declaration he will get in touch with you to see if there is possibly a paper declaration that was not sent in.
In Reno he said that ideally he prefers the electronic declaration. My recent experience is that we handled everything via email and within two days our club member received confirmation of the badge leg.
Badge flying is good in many ways and I am a proponent of its merits.
Lane
XF
New member Shay Farrell Soaring 1 October 4th 09 10:58 PM
Member hurt [email protected] Soaring 0 October 8th 08 05:00 AM
A new member?? Phil Hoare Aviation Photos 6 June 10th 08 08:26 AM
Officially a Member! Douglas Paterson Owning 17 September 12th 07 05:27 AM
SSA Member Area [email protected] Soaring 4 September 5th 06 12:49 AM
