Since I upgraded SYM to 4.3 on my hx4700 it no longer receives GPS data from my LX7007. I've played with the port settings (comm ports, buad rates) with no success. Has anyone else had this problem?
Could be a cable went bad, but I'd like to rule out a software configuration problem ... 2NO |
Hi Ted,
I don't remember whether the LX7007 defaults to 4800 baud or 19200 baud for the PDA output. I think it is documented in the manual. Also, you may need to enable the output of NMEA data in the LX7007. My guess is that it is one of those issues. Best Regards, Paul Remde Cumulus Soaring, Inc. "2NO" wrote in message news:29124016.2189.1335064371415.JavaMail.geo-discussion-forums@vbq19... Since I upgraded SYM to 4.3 on my hx4700 it no longer receives GPS data from my LX7007. I've played with the port settings (comm ports, buad rates) with no success. Has anyone else had this problem? Could be a cable went bad, but I'd like to rule out a software configuration problem ... 2NO |
Thanks Paul -- I went through all those things as soon as I had trouble, but nothing worked.
I thought I had it fixed yesterday but it stopped working halfway through a 500k task. If you're going to lose your moving map, do it at 16k ... 2NO |
SeeYou Mobile Group Available? | JohnDeRosa | Soaring | 3 | December 2nd 11 01:42 AM |
SeeYou Mobile 3.0 now available | [email protected] | Soaring | 0 | February 4th 08 12:17 PM |
Using mobile SeeYou | Robert Hart | Soaring | 3 | May 10th 06 09:42 PM |
SeeYou MOBILE v2.0! | Roy McMaster | Soaring | 10 | July 12th 04 12:25 AM |
SeeYou Mobile | Robert Fidler | Soaring | 0 | March 17th 04 04:18 PM |
