Max towing weigth for PA-18 150 hp and 180 hp?
Old April 22nd 12, 08:06 PM posted to rec.aviation.soaring
Robert Danewid[_2_]
Default Max towing weigth for PA-18 150 hp and 180 hp?
What is the max towing weight (max weight of the glider) for the PA-18 150 hp and 180hp?
Where can I find information on this (on the net).
Thanks!
Robert
ASW 28-18E
Old April 22nd 12, 09:40 PM posted to rec.aviation.soaring
Thanks!
Robert
ASW 28-18E
I have never seen any Piper limitations published.
The tow hook installed is likely the limiting factor.
FWIW
UH
Old April 22nd 12, 11:29 PM posted to rec.aviation.soaring
Bill D
Thanks!
Robert
ASW 28-18E
As long as a Tost hook is installed, there are practically no limits.
There are two 180 HP PA-18's operating out of Boulder, CO where
density altitudes can reach 9,000'. They routinely tow fully loaded 2-
seaters. The PA-18-150 has significantly less performance which is
why none are used in Colorado. While information on hooks is
available on-line, towing performance probably isn't.
I recall the late Dave Johnson, who developed the STC for the 180HP
Cub, saying a 180 HP Lyc. O-360 is only a few pounds heavier than the
original O-320. He went on to say it seems like the extra 30HP
provides a lot more performance than one would expect.
The Schweizer tow plane hook has a limit of 1200 pounds which is
inadequate for heavier gliders but the Tost hook limit is 2570 Lb
which easily handles any glider. For that and a lot of other reasons,
the Schweizer hook should be retired.
Old April 22nd 12, 11:43 PM posted to rec.aviation.soaring
Robert Danewid[_2_]
Thanks
My problem is that some one has found a supplement named S1A-77 to the Flight Manual of a 180 hp PA 18 that says that max glider weigth is 600 kg. Can any one send me or direct me to that supplement.
It does not make sense...... We have been towing gliders 600 kg with PA 18 150/180 since the early 80ies.
Robert
Old April 23rd 12, 12:01 AM posted to rec.aviation.soaring
Craig R.
At first blush I'd say that information was not from the USA. I don't recall ever seeing any US aviation restriction stated in kilos, but I could be wrong. Just a thought.
Old April 23rd 12, 02:08 AM posted to rec.aviation.soaring
Bill D
On Apr 22, 4:43*pm, Robert Danewid wrote:
Thanks
Robert
OK, having nothing else to do this afternoon, I did some research.
The 600kg number suggested a European sourced supplement. US STC's
would likely be in SAE units.
It appears there is a MOGAS STC issued in Switzerland to Wenger &
Kaufmann for PA-18-180-M and PA-18-150 glider tugs. In pursuit of the
STC the glider tow performance (takeoff roll, climb rate) was measured
with a 600kg glider in tow. Since that is the heaviest glider tested,
that became the limit for the STC. This may or may not the source of
S1A-77 but it shows how it can happen. There are LOTS of different
STC's for PA-18 around the world.
This is a bit if a diversion but most recent European 2-seaters
specify 600kg (Actually, 600 daN) weak links for aero tow. If these
gliders are operated in strict compliance with their Approved Flight
Manuals as required by FAR 91.9, 600kg would be the max load on the
tug.
I have been assuming (possibly in error) that you are in the US.
Old April 23rd 12, 08:02 AM posted to rec.aviation.soaring
Robert Danewid[_2_]
Thanks
Robert
The 600kg number suggested a European sourced supplement. *US STC's
Kaufmann for PA-18-180-M and PA-18-150 glider tugs. *In pursuit of the
with a 600kg glider in tow. *Since that is the heaviest glider tested,
that became the limit for the STC. *This may or may not the source of
S1A-77 but it shows how it can happen. *There are LOTS of different
specify 600kg (Actually, 600 daN) weak links for aero tow. *If these
tug.
I am in Sweden
Thanks for your info
Robert
Old April 23rd 12, 10:20 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Thanks
Robert
tug.
Can't agree that most recent European 2 seaters specify 600kg weaklinks for aerotow. The Duo Discus for example is 50% or so higher and the DG 1000 is higher again at 1100 DaN
Having said all that here in New Zealand there are some operations that use PA-18 180s and they variously tow Duos and ASH 25s so they are well capable of handling the bigger ships subject to density altitude considerations
Colin
Name:	Weak links.jpg
ID:	55283  Click image for larger version
Name:	Weak links 2.jpg
Old April 24th 12, 04:05 AM posted to rec.aviation.soaring
Bill D
On Apr 23, 3:20*pm, Ventus_a
Bill D;813718 Wrote:
On Apr 22, 4:43*pm, Robert Danewid wrote:-
Thanks
Robert-
tug.
for aerotow. *The Duo Discus for example is 50% or so higher and the DG
considerations
Colin
|Filename: Weak links.jpg * * * * * * * * * * * * * * * * * * * * * |
|Download:http://www.aviationbanter.com/attachment.php?attachmentid=55283|
|Filename: Weak links 2.jpg * * * * * * * * * * * * * * * * * * * * |
|Download:http://www.aviationbanter.com/attachment.php?attachmentid=55284|
Ventus_a
From the DG-1000 manual page 2.10: "6000 N + 600 N (1323 lbs. + 132
lbs.) for tow
behind slow tow planes" Which I think would include a PA-18.
The Duo allows a 700 daN weak link but that's not 50% higher.
Old April 24th 12, 09:58 PM posted to rec.aviation.soaring
Steve
Checked FAA Advisory Circular 43-13.2, Chapter 8. May or may not help Euro ops, but...
Early on it explains how the structural limits of various tow aircraft are determined. There is a simple formula given for that determination. Tow limits for US aircraft are based on structural limits for the aircraft, not performance limits. Generally, the FAA uses the breaking strength of the tow rope to determine the max weight of the towed glider. Also that weight is usually placarded around 1200 lbs. maximum towline strength to comply with the structural limitations, depending on the aircraft.
In conjunction with that, the FAA also states operationally that the tow line strength for the glider must be no less the 80% of the glider weight or no more than 200% of that weight. So, at least in the US, a tug with a 1200 lb, tow line limit can legally and theoretically to up to a 1500 lb glider (Cub and 2-32?), and still be with in the limits of the towing aircraft. The aircraft performance capabilities are another story and are the responsibility of the operator.
Don't know if this could help or not.
Linwood
Towing with a VW [email protected] Soaring 15 December 7th 07 08:20 AM
Towing with a 150 hp Pawnee? [email protected] Soaring 5 November 22nd 06 01:32 PM
Towing to the airport drano Home Built 3 August 25th 06 06:17 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
FAA says towing ULV's is OK? ken ward Soaring 4 September 30th 04 03:12 AM
