PowerFlARM at R5N Perry
Old April 23rd 12, 03:17 AM posted to rec.aviation.soaring
Ben[_4_]
Default PowerFlARM at R5N Perry
How did PowerFLARM perform at Perry? Understand Dave Nadler was there
as the PowerFLARM rep to address concerns raised at the Seniors. What
up Dave?
FLARM works exceptionally well in Europe. Other than frequency, what
is the difference in the USA unit. Did the FCC require the FLARM
technology be changed for the USA unit?
Old April 23rd 12, 03:48 PM posted to rec.aviation.soaring
Dave Nadler
Default PowerFLARM at R5N Perry
up Dave?
I will post something later today, stand by...
FLARM v5 conforms to FCC requirements for frequency use and hopping.
PowerFLARM has a more powerful transmitter than older units, and
is FCC-approved.
See ya, Dave "YO electric"
Old April 24th 12, 03:42 AM posted to rec.aviation.soaring
Dave Nadler
Please see: http://powerflarm.us/2012/04/powerfl...rt-from-perry/
Old April 24th 12, 04:18 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Thanks for the report, Dave. It sounds like they are getting a handle on
the problems.
Is it acceptable to install the antennas inline, one behind the other?
Maybe leave the Flarm antenna on the box and mount the PCAS antenna
forward of it? That would reduce the visual impact to just one antenna
(it's not a big issue, as I'm getting used too two antennas, but seeing
just one would be nicer).
email me)
Old April 24th 12, 05:38 AM posted to rec.aviation.soaring
Kimmo Hytoenen
Please see: http://powerflarm.us/2012/04/powerflarm-report-
from-perry/
It bis clear that any metal near the antenna disturbs
transmit/receive. How about the pilot? some sources say, that
human body is practically invisible for 868 MHz radio waves, some
people say that if you install antenna behind the front pilot in
double-seater, the transmission is blocked by pilots head.
Clear answer would be appreciated.
-kimmo
Old April 24th 12, 04:15 PM posted to rec.aviation.soaring
db_sonic[_2_]
I am hearing news the PowerFlarm brick is released in the Europe? US
to follow soon??
Old April 24th 12, 05:15 PM posted to rec.aviation.soaring
mattm[_2_]
On Apr 24, 11:15*am, db_sonic wrote:
I am hearing news the PowerFlarm brick is released in the Europe? *US
to follow soon??
The Powerflarm product page has pictures and prices on it (and also a
"pure"
version without ADS-B or transponder detection).
http://www.butterfly-store.de/
No manuals yet, though.
Old April 30th 12, 09:51 PM posted to rec.aviation.soaring
Darryl Ramm
from-perry/
-kimmo
At these frequencies a human head is likely to have significant attenuation and putting a PowerFLARM or other similar devices (including PCAS receivers) in a two seater where its likely to be obstructed looking forward (where threat aircraft you might hit may be more likely to be..) is a bad idea. (You can Google for many documents on RF absorption of the human body). Another possible issue is metal components in front-seat headrests etc. And if the cockpit frame contains any metal parts (e.g. steel roll bars etc. -- I have no idea if common two seaters have steel roll bars in the canopy mid-frame) these may also be issues.
It seems a significant number of folks seem to be having problems mounting their PowerFLARMs properly hopefully this problem, can be reduced by revisions to the documentation. And the brick-version should make better antenna location easier for many owners--but I fear we'll still have a bunch of antennas installed below the glareshield buried amongst wiring, not vertically orientated, damaged/kinked coax, loose SMA connectors, etc ...
Darryl
Old May 1st 12, 01:09 AM posted to rec.aviation.soaring
Dave Nadler
-kimmo
At these frequencies a human head is likely to have significant attenuation and putting a PowerFLARM or other similar devices (including PCAS receivers) in a two seater where its likely to be obstructed looking forward (where threat aircraft you might hit may be more likely to be..) is a bad idea. (You can Google for many documents on RF absorption of the human body)........... (etc, its Daryl typing)..... etc...
Yes, but, (wait for it, drum-roll)...
Some heads are thicker than others.
Day 3 at Perry Frank Paynter[_2_] Soaring 1 April 23rd 11 12:32 AM
Day 1 at Perry Frank Paynter[_2_] Soaring 0 April 19th 11 02:08 AM
Perry, SC, USA info Ray Lovinggood Soaring 1 April 20th 07 05:48 PM
Perry, SC, USA Ray Lovinggood Soaring 0 February 17th 06 06:53 PM
Perry, SC GM Soaring 12 May 13th 05 01:26 AM
