G102 Club III Brake replacement
Old May 23rd 12, 01:07 PM posted to rec.aviation.soaring
Hartley Falbaum
Default G102 Club III Brake replacement
MGSA's G102 is in need of new brake system--or rebuild for old one. I
have emailed Linder for for info, part numbers, etc,no response so
far. I am told it is a BMW motorcycle brake, from Magura.
I am located in the Atlanta, Georgia, USA, and have sources for BMW
motorcycle parts.
The master cylinder is back behind the seat pan, and not easy to get
to--anybody know any tricks to make it easier?
I would really like the BMW or Magura part numbers, or the the Bike
model, if anyone knows them. Otherwise, I'll have to disassemble and
measure. Being able to remove and replace same day would be nice.
Thanks in advance
Hartley Falbaum
"KF" USA
Old June 7th 12, 07:36 PM posted to rec.aviation.soaring
Stephen zikora
motorcycle parts.
Thanks in advance
Hartley Falbaum
"KF" USA
I have rebuilt the brake system on a G103A and it is likely the same.
You are correct that the master cylinder is a Magura unit as used on a
BMW motorcycle. You can order a rebuild kit or even a new master
cylinder from a local BMW Motorad dealer. As I recall, it was a common
unit used for several years in the late '70's and early '80's. I
ordered the kit after measuring the bore size - that was the best way
to make sure you get the right one and the dealer will identify it by
that size. The rebuild involves dis-assembly, cleaning, honing of
cylinder, and re-assembly using new seals.
Now, you only need this kit if your master cylinder is not working or
leaking. Try bleeding the brakes first. And interesting note about the
G103A was that the caliper was a Cessna unit! The best way to bleed it
is from the caliper up, not from the master cylinder down. Once tuned
up, you will find that the system is amazingly effective. I like
having brakes and I'm always amazed that most gliders I've flown have
none either by poor design or poor maintenance.
G102 retractable gear John Murphy Soaring 2 June 17th 09 05:30 AM
G102 spigot AD??? What's the status... Gary Emerson Soaring 31 August 22nd 08 10:39 PM
G102 Wing Inspection Panel Tim[_1_] Soaring 2 August 13th 08 02:40 AM
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
Wheel Brake on G102 Ken Pruchnick Soaring 4 March 2nd 05 07:01 AM
