XC Soar Map for Parowan task area?
Old June 19th 12, 05:09 AM posted to rec.aviation.soaring
Sean F (F2)
Default XC Soar Map for Parowan task area?
I cannot get the map generator to work? Anyone have a map built?
Please email to if you can.
Thanks in advance!
Sean
Old June 19th 12, 05:27 AM posted to rec.aviation.soaring
Tim Taylor
On Jun 18, 10:09*pm, "Sean F (F2)" wrote:
I cannot get the map generator to work? *Anyone have a map built?
Thanks in advance!
Sean
Jim Darke has maps available at Parowan. He makes the best maps I have
seen. I have his maps for Montegue, Logan and Mifflin. I have one
waiting for me when I arrive at Parowan tomorrow.
Old June 19th 12, 05:33 AM posted to rec.aviation.soaring
Tim Taylor
Thanks in advance!
Sean
Sean,
Sorry, misread the post. See you need the background map to run with
XCsoar.
Old June 19th 12, 06:05 AM posted to rec.aviation.soaring
Thanks in advance!
Sean
Internet Explorer never works. I have to use Firefox to get it to work properly. The tool usually spits out a map in less than 5 minutes once you "place your order".
Old June 19th 12, 06:40 AM posted to rec.aviation.soaring
Ramy
Sean, if you still can't get the generator to work in Firefox let me know and I can email you my map. It covers most of western states so pretty large file but if you have modern PDA or tablet like the Streak it shouldn't be a problem.
Ramy
Old August 28th 12, 07:21 PM posted to rec.aviation.soaring
Ramy
This is a somewhat ancient topic, but I'm having trouble with the map
generator today. I put in a request to generate a map covering South
Carolina but it remains queued hours later. Does anyone know what's going
on with the generator? There isn't any chitchat about it on the mailing
list archive and the old xcsoar forum archive isn't available.
-- Matt
Old August 29th 12, 07:27 AM posted to rec.aviation.soaring
Tobias Bieniek
Hi Matt,
we know that the map generator is sometimes/often broken due to overload. There is one utility application (gdalwarp) that we use to generate the terrain map that is using very many resources of the server and it seems that from time to time it just freezes. In that case we have to restart the service and all is fine again, but we usually don't notice it unless someone is complaining. I'm sorry that the service isn't as reliable at the moment as we wish it was.
Have you checked out the pregenerated maps? Is there nothing for the area where you want to fly in?
Turbo
Old August 29th 12, 03:10 PM posted to rec.aviation.soaring
On Wednesday, August 29, 2012 2:27:09 AM UTC-4, Tobias Bieniek wrote:
Hi Matt,
Turbo
No, nothing in the SE USA. Too bad, since there's 4 contests in the region
this year. I had generated a map for my own club's use, but it doesn't cover
the area we're flying in this weekend when visiting another operation.
-- Matt
Right seat NY area to Boca Raton area doylflier Piloting 0 May 30th 07 01:06 PM
winpilot assigned area task [email protected] Soaring 2 April 18th 07 04:08 AM
New DMSt task: 4 TPs Klaus T. Soaring 0 January 9th 06 12:03 AM
New Task JJ Sinclair Soaring 5 October 23rd 03 01:36 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 04:12 PM
