O2 Cylinder Sizes - What are people using these days?
Old June 26th 12, 04:36 PM posted to rec.aviation.soaring
Bob Kuykendall
Default O2 Cylinder Sizes - What are people using these days?
I'm looking to develop a standard O2 cylinder installation for the
HP-24 sailplane kit, and I'm curious what size cylinders people
generally have installed these days.
These days a lot of folks seem to be using EDS systems which seem to
offer very good efficiency at turning pressurized gas into blood
oxygen. So less pressurized gas is needed than back in the old days
when we were all using surplus A8A regulators.
This webpage lists what seem to be the the standard O2 cylinder sizes
these days:
http://www.mhoxygen.com/index.php?op...t emid=50#pdf
The cylinder sizes I generally see referred to in forums like these
are these medical sizes:
D-size: 4.4 in/11.1 cm diameter, 18.7 in/47.4 cm length, 14.7 ft^3
volume
JD-size: 5.3 in/13.3 cm diameter, 18.1 in/46.0 cm length, 22.8 ft^3
volume
E-size: 4.4 in/11.1 cm diameter, 27.0 in/68.6 cm length, 24.1 ft^3
volume
The information I'm looking to collect is, what size cylinder do you
actually have installed, and does it generally meet your needs?
Thanks, Bob K.
http://www.hpaircraft.com/hp-24
Old June 26th 12, 04:47 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
offer very good efficiency at turning *pressurized gas into blood
these days:
http://www.mhoxygen.com/index.php?op...ew=article&id=...
volume
volume
volume
Thanks, Bob K.http://www.hpaircraft.com/hp-24
But the great thing about a bigger bottle is that you get decent
capacity even when the filling station is a little low. Always seems
to happen at some point at wave camp. Very happy that my '20 takes an
E-size bottle, even if it is the old, awkward, heavy steel E-size.
Best -- imo -- would be provision to install either D or E size
aluminum bottles. These are common and inexpensive.
Evan Ludeman / T8
Old June 26th 12, 05:12 PM posted to rec.aviation.soaring
Mike C
these days:
volume
volume
volume
JD size is ideal. Good flight times even with a constant flow
oxysaver cannula systems.
Old June 26th 12, 05:13 PM posted to rec.aviation.soaring
Bill D
these days:
volume
volume
volume
I just reached across my desk for just such an O2 bottle. It's a
AL-647 from MH. For me, it supplies about 12 hours of O2 when flying
in the 14k' to 18k' range. The label says it holds 22.8 Cu. Ft. @
2216 PSI. The dimensions appear to be what you list as a JD-Size.
While the HP-24 can have any mounting you choose, existing gliders are
usually designed for European bottles. MH bottles don't have a 'neck'
for easy mounting like the European style bottles. A suitable neck
can be fabricated from a male & female CG540 fittings and a short
brass pipe. I turned a sleeve of HMWPE to slip over the pipe to
increase the diameter so it fits the mounting clamp in the glider.
FWIW, I've wondered if mounting long, small diameter "pencil" bottles
in the wing roots might be a solution to keep the fuselage less
cluttered.
Old June 26th 12, 06:58 PM posted to rec.aviation.soaring
RobKol
On Jun 26, 8:36*am, Bob Kuykendall wrote:
CFI-480
http://www.flickr.com/photos/7288548...7629247935565/
Robert
volume
volume
volume
Old June 26th 12, 07:27 PM posted to rec.aviation.soaring
Bob Kuykendall
CFI-480http://www.flickr.com/photos/72885489@N00/2231164294/in/set-721576292...
Robert
Nice mods on the Jantar! Let me know when you're ready to build a
glider from scratch.
Thanks, (the other) Bob K.
Old June 27th 12, 12:32 AM posted to rec.aviation.soaring
Bob Kuykendall
Thank you all for your information and suggestions!
Bob K.
Old June 27th 12, 01:03 AM posted to rec.aviation.soaring
Tim Taylor
Bob K.
The JD or E if you have space. I have a D and it is a little small.
Loved the JD in my last plane.
You can get any of these for about $100 throught the EMT supply market
with both valve types.
Old June 27th 12, 01:15 AM posted to rec.aviation.soaring
Brad[_2_]
these days:
volume
volume
volume
EDS system. AL415 bottle secured to the forward lift tube.
Brad
Tetra-15
Old June 29th 12, 07:38 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
these days:
volume
volume
volume
Brad
Tetra-15- Hide quoted text -
- Show quoted text -
Brad,
What size is that?? I've been looking for days on various sites for a
new cylinder, and I've concluded that each VENDOR comes up with their
own 'standard' for naming the cylinders. I was thrilled to note that
the cylinder in the Janus C was an enormous 39 Cubic Feet, and crushed
when I found it was the special thin wall steel cylinder with a
limited life, which had expired NINE YEARS AGO.
"Airplanes don't kill people!, people kill people!" Laonork Owning 8 May 21st 12 05:56 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Owning 2 May 24th 07 05:26 AM
Oil in cylinder, other cylinder issues Robert M. Gary Piloting 0 May 23rd 07 10:44 PM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 0 May 23rd 07 10:44 PM
"Airplanes don't kill people!, people kill people!" Flyingmonk Piloting 11 May 17th 05 10:26 AM
