Certified to Experimental?
Old December 3rd 03, 06:51 PM
Jeff Franks
Default Certified to Experimental?
Just wondering. Is it possible (read practical) to take a certified
aircraft (C172 for example) and have it "demoted" to an Experimental?
Seems there are LOTS of great options out there for non-certified flight
instruments (EFIS's and such) available for not much more than a song and a
dance, but you can't put them in a certified plane (my understanding
anyway).
If I'm a fair weather, non-commercial pilot, why would I care if the FAA
stamped my alternator or not? Cause if they do, the price jumps 500% for
the same part that's on my Dodge.
(all that said, I understand that the certification is there for safety
purposes and that I will lose the "promise" of the FAA saying that its a
well proven part).
Thanks
Old December 3rd 03, 07:09 PM
Dan Luke
FAA stamped my alternator or not?
You might not care about your alternator, but you probably *would* care
when you found out what your "experimental" 172 was worth when you tried
to sell it.
Dan
C172RG at BFM
Old December 3rd 03, 07:18 PM
Peter R.
A few weeks ago, I saw a 2003 C182 that had been "demoted" to an
Experimental due to the installed Garmin G1000 avionics. I was told that
this aircraft could not carry passengers because of this status, so we were
unable to see the avionics in action.
FWIW...
Peter
Old December 3rd 03, 07:23 PM
Peter Duniho
"Jeff Franks" wrote in message
See Part 21. In particular, 21.191 summarizes the kinds of experimental
certificates available.
In answer to your question: it IS possible to get an experimental certficate
for a C172. However, I don't think you'd be able to use either the
"amateur-built" or "kit-built" categories if all you've done is put
non-certified equipment on the plane. And it's unlikely you'd find the
restrictions on the use of your airplane acceptable in the other categories
of experimental certificate (and only a couple others allow the certificate
to last indefinitely anyway).
In other words, I don't think there's any practical way to accomplish what
you're asking about. I suppose you could dismantle a C172 completely, build
a "new" plane from scratch from the parts, and call it "amateur-built". But
if you're going to go to that much trouble, I'd just build a real homebuilt.
Pete
Old December 3rd 03, 08:02 PM
Dale
It's possible and is done quite a bit for specific purposes. An example
would be many aircraft in Alaska that are operated in the "Restricted"
category allowing them to carry things like canoes strapped to the
floats, plywood in a rack under the belly, etc.
Being in the "Experimental" category has some restrictions. You operate
under a letter from the FAA that outlines "Operating Limitations". Some
of the restrictions that apply to a/c operated as "Experimental" are no
operation for hire, no skkydiving allowed, you may or may not be able to
carry passengers other than required crew, no operation over densely
populated areas or in congested airways, VFR only. There may also be
restrictions on how far from home you can go.
As another poster mentioned, when it comes time to sell unless the buyer
wants an experimental airplane you either have the expense of getting
the airplane back to "Standard" or reduce the price.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old December 4th 03, 12:29 AM
BTIZ
could not carry pax in an experimental? happens all the time...
many home builts and gliders are certified experimental..
the aircraft must be marked "experimental" in letters of a stated size and
in an area visible to the pax
must have been an insurance thing..
BT
"Peter R." wrote in message
were
FWIW...
Peter
News==----
Newsgroups
Old December 4th 03, 12:49 AM
Neal
On Wed, 3 Dec 2003 16:29:35 -0800, "BTIZ"
When the FAA grants an experimental cert on a former standard cert
aircraft, they virtually always remove your ability to legally carry
pax afterwards. This is the established precedent.
What we need is an "experimental-antique" type of cert that would
allow full owner maintenance and simple A&P annual "condition
inspections" on old, small planes just like the homebuilt aircraft
enjoy today.
Old December 4th 03, 12:57 AM
Peter Duniho
"BTIZ" wrote in message
news:Jdvzb.2374$yf.275@fed1read01...
Not all experimentals carry the "amateur" or "kit-built" designation.
True, for experimentals that are permitted to carry passengers. So?
No, it was more likely an FAA thing. As in, with the installed avionics,
the plane was probably being operated under an R&D or "showing compliance"
designation, neither of which allow the carriage of passengers.
Pete
Old December 4th 03, 01:03 AM
BTIZ
"Peter Duniho" wrote in message
True
and
just a side bar note
Pete
could be...
Old December 4th 03, 01:06 AM
Robert Moore
There are several categories of "Experimental".
1 Amateur Built
2 Exhibition
3 Research and Development
4 Air Racing
5 Crew Training
6 Market Survey
7 To Show Compliance With The CFR
Sounds as if you are only familiar with Amateur Built and Exhibition.
Bob Moore
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
